PTO Generator for B2400
   / PTO Generator for B2400 #1
FFC_Fencing
Northwest Indiana
New Holland TL90; New Holland TN65; two PT 425; One PT 422; Swinger 2000; Bobcat 773
Any experience with a PTO generator on a B2400? How would such a set up compare with a portable generator?
   / PTO Generator for B2400 #2
My neighbor has a PTO set up for an 80hp Agco. The tractor idles and powers the house with the generator. The generator sits on a palette about 5 ft from the tractor (it's not on the 3pt).
I have a second neighbor that must run his 60hp JD diesel at pto speed. Makes for a noisey experience.
From what I can tell, all generator heads run at about 3000 RPM. So my Agco neighbor must have a gear box to increase the shaft speed. Or maybe a 2 speed PTO. Either way, I like the fact the engine sits at a quiet, non-gas-guzzling rpm.
I've often thought about this sort of arraingment for my B2400. The way I see it, a gearbox with 1850 input and 3200 output should be about right.
One other thing I've noticed about this kind of set up, buying a PTO driven generator is a lot more expensive than buying a 10hp, 5500Watt portable. Maybe if the generator head were purchased separately and then the whole thing cobbled together the prices would come out even?
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
Year: 2012 Make: Chevrolet Model: Traverse Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 177,... (A51694)
Year: 2012 Make...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
