Generator pto generator / florida huricane
   / pto generator / florida huricane #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
First.. a 'good luck' to my fellow floridians ( and that goes for you south georgia and carolina people as well ). Hope we don't get hammered too hard.
On a related topic. I think I've finally decided to purchase the 13000/12000 watt pto generator from northern tool. I see that it mentions an input shaft , 6 spline, 1 3/8"
I take that to mean that it has a standard male pto stub like our tractors do. Am I thinking correctly? If so, then i can get a 150$ 6 spline to 6 spline drive shaft from tractor supply locally, instead of ordering the 190$ + shipping $$ one northern sells. Anyone see a problem with this thinking?
Thanks!
Soundguy
   / pto generator / florida huricane #2
Soundguy,
I can't help you with your question but have you checked on ebay for the PTO shaft? I've seen them on there for less than $100.00. I wouldn't have noticed them except for the recent thread where the guy tried to pull apart his stuck PTO shaft.
Rodger
   / pto generator / florida huricane #3
Soundguy
<font color="blue"> I see that it mentions an input shaft , 6 spline, 1 3/8"
</font>
You are correct on the spline size.
Have you tried Agri-Supply.
Their prices are less than Northern Tool.
Taking a look there right now.
thnaks guys.
Soundguy
   / pto generator / florida huricane #5
Soundguy,
Be sure and let us know how the generator turns out, I have been thinking of buying the same generator.
Good luck with Francine.
   / pto generator / florida huricane #6
</font><font color="blue" class="small">( First.. a 'good luck' to my fellow floridians ( and that goes for you south georgia and carolina people as well ). Hope we don't get hammered too hard. )</font>
Thanks Chris, and it looks like I should bid you that double as the weather people here in Jax are now telling us that we will probably only be getting 40-50 mph winds starting Sat. and that further south will get it worse. I hope Ocala doesn't do any worse. Good luck with the generator. I will also be interested to know how it does as I am going to sell the RV and there goes my generator! John
   / pto generator / florida huricane #7
Soundguy
Just remember that PTO shafts are rated for the amount of power they can transmit. For that generator @ 746 watts per hp with an 80% assumed efficiency you need about 21 pto hp to achieve rated output. Startup surges could be much higher. Good luck with the storm.
Andy
Kiotijohn and slowrev. As soon as I get the genny and get some use on it I'll post back about it.
Thanks for the thoughts.
Soundguy
</font><font color="blue" class="small">( For that generator @ 746 watts per hp with an 80% assumed efficiency you need about 21 pto hp to achieve rated output. Startup surges could be much higher. Good luck with the storm. )</font>
Yep.. I agree. I had originally thought about a 150$ one from TSC as opposed to the 190$ one at northern, but I found out the TSC one was 36" and only rated for 24 hp.. I didn't feel too good about that, and moved up to a 50" one that was rated for 90hp, and that almost matches the specs line per line for the norhtern one.. so I felt much better about it. Still saved about 25$ over northerns cost.. so that was a good deal.
I also noticed that northern ran an unadvertised special on those 13/12kw gennies.. They are listed at 1099.00 in the catalog and the internet site.. but I got mine for 999.00?? Florida sympathy discount? Whatever.. I'll take it. That discount paid for half of the 'priority' shipping.. which i felt was a pretty reasonable rate for a truck freight item...
Soundguy
   / pto generator / florida huricane #10
I just bought a 42" 40hp shaft from the local CaseNH dealer to use on my Bush Hog. Cost was just under $110.
I have had a PTO generator for 20 yrs. Takes a little while to hook up but works great. Mine is a 7KW but that was all I could drive with the B6100E Kubota I had. I will have to replace it soon as the electronics are beginning to fail and it is an orphan.
Vernon
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
JOHN DEERE  EURO BUCKET (A52472)
JOHN DEERE EURO...
