PTO Gear keeps jumping out of gear
   / PTO Gear keeps jumping out of gear #1
Buster747
LA (Lower Alabama)
L5030 HST
I have a 1970-72 Ford 3000 Desiel
This happens all the time while bush hogging, I have to ride with my foot resting on the PTO lever to keep it in gear.
Any ideas, all help is appreciated.
Looking for answers
:licking::licking::licking:
   / PTO Gear keeps jumping out of gear #2
with pto shaft disconnected and engine off.. pto not engaged.... grab pto stub .. i bet it has a lil in / out play.. that is called thrust play.
generally it is a slipped out split ring holdingthe gbearing.. could be bad bearing or slipped seal wear ring. or could be damaged ebaring carrier.
letting it slip out eats up the engagement collar and can hammer the rear of the pto shaft till it mushrooms making it near impossible to pull out.
it's a 4 bolt job to pull the shaft.. park nose down to not loose oil.. tie pto to engaged before you pull her.
lastly.. sometimes , rarely.. it is a worn / loose detent.. and sometimes you are not getting full travel / engagement of the lever / coupler
post back for more info
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
3 Boxes of Printer Accessories (A51695)
3 Boxes of Printer...
2018 Atlas Copco Pas200HF water pump powered by Duetz diesel engine with Bin Pump (A52377)
2018 Atlas Copco...
2008  BIG TEX 16' T/A TRASH TRAILER (A53843)
2008 BIG TEX 16'...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
ALLISON TRANSMISSION (A53843)
ALLISON...
