PTO Fuse Blows Under Load
   / PTO Fuse Blows Under Load #1
PhilGG
TYM 273 HST
I have a 2008 TYM 273 HST. The problem is that whenever the PTO is under a load for several minutes, the 7.5A fuse blows. It appears the warmer the engine or ambient temperature, the quicker the fuse blows until it only moves a few feet and blows (this, of course, happening after it has just been replaced). I’ve replaced the PTO ON/OFF switch and swapped out the PTO shaft. No luck. I’ve reset the fuse slot to get a better grip on the fuse, but still no luck. I’ve checked for loose wires and harnesses, but can’t find any.
When I engage the PTO for the Brushcutter, it shakers at max PTO RPM, but that doesn’t seem to trip the fuse.
Any help or suggestions would be appreciated.
   / PTO Fuse Blows Under Load #2
Guess is you have a wire with worn insulation somewhere, and as things vibrate it shorts. Just a guess. I'm away from home and my manuals and tractors so can't look at things to come up with a better response.
   / PTO Fuse Blows Under Load #3
When I had a 273 I had a lot of problems with chafed wiring harness under the dash. I built a subframe connector to stop the chassis from flexing.
Thanks for your replies guys. I’ll try harder to inspect those wires under the dash and look at the wire insulation. I’ll definitely give feedback on what I find.
   / PTO Fuse Blows Under Load #5
I'll sure be interested to learn whatever you find out is causing this! My 273 is a 2009 model and hasn't given me any pto problems - YET - but I'm always ears as to what "Might" be next to plague me! Thanks for any feedback!
1990 PETERBILT 320 HYDROVAC (A55745)
1990 PETERBILT 320...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
New/Unused Root Rake for CFG Mini Excavator (A54865)
New/Unused Root...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
