Mowing PTO fuse blows - Brandon 4220i
   / PTO fuse blows - Brandon 4220i #1
viejoloco
Sunset, Tx
Brandon 4220i
We were mowing Saturday and all the sudden the PTO light went out and quit working.
We found the fuse blown and replaced it. The turn on the tractor again and went to turn o. PTO and nothing, check fuse and it was blown. So replace it with switch off but tractor on and it blue on our hands.
Could it be the solenoid is in short ?
Any ideas?
It is my first post so I hope it is in the right place.
   / PTO fuse blows - Brandon 4220i #2
I don't know anything about brandon's,but if your a "do-it- yourselfer",
try and remove the the solenoid and put another fuse in, if it still blows, it's not the solenoid.
Could be a broken wire grounding out from or to the solenoid.
Thanks, Solenoid was our first thought too. Tractor has less than 200 hrs.
Anybody has the wiring diagram? or idea where the Solenoid is located?
Thanks Skyhook
   / PTO fuse blows - Brandon 4220i #4
I would suspect a wire shorting out Vs a bad coil. PTO solenoid should be on the side of the transmission housing. I believe Branson has an on-line parts diagram website.
2012 International Semi Truck (A50323)
2012 International...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
1981 Case 245 2wd tractor with Rotary cutter (A51039)
1981 Case 245 2wd...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
