pto for d1550fd
   / pto for d1550fd #1
47hotrod
vincent
d1550fd
Trying to find overriding pto clutch for Mitsubishi d1550fd 18 spline to 6 spline
   / pto for d1550fd #2
Something along these lines? SpeeCo Over-running Clutch Adapter, Male Spline 1-3/8 in. x 6 - Tractor Supply Co.
The picture just looks like a PTO adapter, but the narrative describes an overrunning clutch. If it is just an adapter, then you'd need to get a standard over run clutch to slip over the adapter, which would not only get fairly expensive, but it'd extend your PTO way out there and you'd have to shorten your implements PTO shaft.
I found some time to do a little more searching, try these people out: PTO Shaft Adapters - Pto Driveline Parts - More Ag Parts
   / pto for d1550fd
Thanks a lot. found a adapter but still want over-riding clutch. thanks again
   / pto for d1550fd #4
You can usually find one at Tractor Supply.
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
378811 (A51573)
378811 (A51573)
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A52377)
2013 GMC Sierra...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
