PTO feathering term usage
   / PTO feathering term usage #1
Tractorguy1038
Bronze Member
upstate NY
Cub Cadet Yanmar EX 3200
Some examples:
New Holland T4000F
Switchable 540/1000 rpm PTO allows you to run a variety of implements. The PTO operates independently of the tractor driveline. Hydraulic servo-assist PTO engagement provides for low-effort PTO engagement with feathering capability.
Permco PTO controls
Kicks the PTO out of gear automatically when the control lever for the dump pump is put into the "lower" position, thus reducing the possibility of running down the road with the PTO in gear. It also feathers, allowing for precise control of the dump body. The unit's compact size allows it to be mounted almost anywhere in the cab, including under the left side of the driver's seat. The 997-01043 assembly includes the console, feathering air shift valve with push-in fittings for controlling the dump pump, air shift valve for the PTO, PTO indicator light, and tubing.
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
JOHN DEERE 444-624 - 60" LOADER FORKS (A52705)
JOHN DEERE 444-624...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
Kubota BX2230D (A47384)
Kubota BX2230D...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
RoGator RG1100C (A53473)
RoGator RG1100C...
