PTO driven generator for standby power: What say you?
   / PTO driven generator for standby power: What say you? #1
RobJordan
Has anyone used a Mahindra in the 18-26 hp range to power pto driven standby generator? Been thinking of getting one for standby power at the house. The concern I have is whether you have to have a governor link-up to the generator to accomodate changes in power loads. With a bigger tractor 40+ hp and a smaller generator (say 7.5 to 10kw) the tractor could handle load changes just fine. I'd like to marry a 18-24 hp Mahindra to a 7.5 kw pto generator. Any experience with a similar set up is appreciated.
Thanks,
Jordan
   / PTO driven generator for standby power: What say you? #2
No personal experience, but an electrical engineering degree and a lot of tractor experience says you need to consider:
1. PTO HP is only about 75% of gross tractor HP
2. 1 HP = .75 KW
3. No generator is 100% efficient (80% is very good, some run as low as 50% or less)
4. Unbalanced electrical load loads the generator (increased inefficiency) more than the average of the two legs if balanced.
Taking the average of your cited HP (if it is gross as opposed to PTO HP), 21 gross HP = 11.8KW at the PTO -- best case that will power about a 9.5 KW generator fully loaded with a balanced load.
What is probably equally important if not more so is how the engine reacts to a sudden increase in load. That's dependent on engine condition, and a bunch of other factors like how big, how sudden, etc. If its just the surge (transient) current of a motor start up, that's different than if its a steady state change.
Your proposed setup should be OK, but without knowing what electrical loads you have and what condition your tractor is in, I can't say it will be "just like the electric company."
   / PTO driven generator for standby power: What say you? #3
IF you don't have either the tractor or the generator, I would get a gas or lp generator and put an external tank on it.
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
2014 PETERBILT 388 AUTO TRANSPORTER (A51222)
2014 PETERBILT 388...
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
2006 ISUZU NPR (A50323)
2006 ISUZU NPR...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
