PTO Disengages Zetor 5211
   / PTO Disengages Zetor 5211 #1
pratera
While bush hogging with my Zetor 5211 my PTO will randomly pop out of gear. It seems to do it on tight turns and anytime the grass gets really thick. After I stop, throttle down and put it back in gear (with clutch of course) it shakes very hard initially then smooths out. If I put my foot in front of the PTO shifter it seems to help. I've noticed it does it on the same spots in my pasture time and time again, usually tight turns or on inclines. I'm wondering if this is the tractor or the bush hog causing the problem. There is no forward/backwards play on the drive shaft. If I raise the bush hog a bit so it doesn't have as much resistance from the thick grass, it doesn't seem to do it.
   / PTO Disengages Zetor 5211 #2
My Century did the same thing when it was new. I discovered the saftey switch was adjusted to tight to the pto shifter lever not letting it fully engage. Adjusted the switch back, problem solved.
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
378570 (A51573)
378570 (A51573)
ABI TR3 LOT NUMBER 147 (A53084)
ABI TR3 LOT NUMBER...
2008 KENWORTH T-300 LUBE TRUCK (A52472)
2008 KENWORTH...
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
