PTO connection helper
   / PTO connection helper #1
reprosser
Midlands of South Carolina
Is JD the only company that makes a "auto hitch" type device that makes connecting PTO shafts easier? My wife is running the tractor a lot, but the PTO connections are tough.
I have a hard enough time getting things attached - with all the safety guards and and twist/push/pull/button type fittings on the different PTO connectors - but she just does not have the strength to manage it. It does not help that the tractor and implements are all new (tight fit).
I am looking for something that will make it possible for her to do the hookups without having to call me off other projects to change out implements. I would not mind at all if it were easier for me too.:thumbsup: I am not getting any younger...
Maybe someone has a DIY solution?
In addition to my attachments, I have a borrowed auger and rototiller.
   / PTO connection helper #2
I think Deere is the only one.
However, I am sure that the "auto" PTO hitch requires the attachment to be Deere and compatible with the new device. When switching attachments a lot (I'm thinking landscaper on a job with several used in sequence), this new 'vention would certainly be handy.
Kudo's to your wife for at least trying. Be careful how quickly you introduce her to the new Deere tool. :) :)
   / PTO connection helper #3
I think the hardest part of hooking up implements is aligning the splines on the PTO shaft to the implement shaft (so that you can slide them together). An overrunning PTO adapter might make this easier (at least you can spin the splines backward to align them).
Peter
   / PTO connection helper #4
my own trial-and-error experiences have taught me that the most important thing is to make sure the PTO shaft on the implement is absolutely "straight" ...in both dimensions, left-right and up-down ...the left-right comes almost automatically, but the up-down needs attention: raising/lowering the implement and playing with the the top link ...and then making sure to shut down the tractor before attempting to make the hookup. A sturdy rope down from the ROPS with an adjustable loop (double half-hitch, e.g.) can hold the shaft and allow you to concentrate on connection. With the tractor off, in neutral, you should have at least 180-270 degrees of free rotation on the driving splined shaft, enough to allow the driven shaft to mate, initially...until it hits the stop. Only now do you need to fuss with the coupler pin/collar/whatever ...and, if it is lined up in both dimensions up-down as well as right-left, it should slip on surprisingly slick (a little lube/grease on the driving splines work, here) ...to repeat just once more, my experience is that the universal on the driven shaft should not be canted in any direction.
   / PTO connection helper #5
I didn't want to do it; but I removed the tractor's PTO guard because it was a PITA to hook up the bush-hog's driveshaft, especially with a Quick-Hitch being used. I left the bush-hogs's driveshaft guards in place.
   / PTO connection helper #6
mjncad
I also removed the guard on the tractor.
IMO, It is only there to hook up the older shields that we use to have to cover the PTO shaft. See no reason for them now (except if the PTO shaft is running and someone is standing on the drawbar). I find sliding the PTO shaft onto the PTO stub much easier now, not having to work around that guard.
A shot of WD40 on the stub and the PTO connector before sliding them together and being sure the PTO is in neutral allowing the stub to be turned are also helpfull to attaching the PTO shaft to the tractor.
   / PTO connection helper #7
mjncad
Due to our dusty conditions, I give the PTO stub a wipe down with a rag before hitting it with WD-40 or something similar.
   / PTO connection helper #8
For me cleaning the PTO shaft and the PTO and then lightly lubing has worked the best. I keep a small wirebrush in the tool box just for that. Since doing that I've had much less problems connecting the PTO shafts.
   / PTO connection helper #9
But I am much more careful around it because of that... I never hook up or disconnect the PTO with the engine running. Also ditto on keeping it clean, wipe dirt off of it. I have never put oil or grease on it...
   / PTO connection helper #10
I feel better. I thought I was the only one who had trouble hooking up the PTO....I never had the tractor in neutral and that probably makes a huge difference. I always tried to slighly move the implement (eg mower) and that is a tough go.
I too, have a helper rope to support the shaft so I can concentrate and use my strength on the connection.
One other question....is it necessary to pull the spring loaded collar back to install or is that only necessary to detach?
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2006 Audi A6 AWD Sedan (A50324)
2006 Audi A6 AWD...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
