pto clutch
   / pto clutch #1
jonc00k
brittany France
iseki tu220f, international b414, Avto t40
I have an iseki tu220f that is a great tractor. the only thing is that when using my flail or rotary mower, when i depress the clutch the momentum of the mower pushes the tractor along by forcing the wheels to turn. is this normal? and if it is can i buy anything that will stop this happening. if it is not normal what can i do about it?
   / pto clutch #2
It is normal with these smaller Japanese tractors which don't have a live or independent PTO. Instead, it's driven off gearing after the transmission (as I understand it) so as the tractor rolls so does the PTO turn. The way around this safety problem is to install a one-way PTO clutch on your tractors shaft. I've seen these listed on E-bay for as little as $15.00 but they are normally around $65.00.
Bill
   / pto clutch #3
I purchased an over running clutch from Agri Supply for my TS1610. It makes work faster as I can change gears from forward to reverse and stop the tractor while my rotary cutter is still turning.
These cost about $24.
   / pto clutch #4
Rich, did you install it yourself.... and if so, just how big of a job was it?
   / pto clutch #5
Yes I installed this. These fit on the PTO output shaft. They are made to be installed and removed as needed. There is also a more expensive version that is quick release.
I don't take mine off the PTO shaft, but from other posts the model I have takes about 15 minutes to remove.
  • 874548-Over Running Clutch View Small.pdf
   / pto clutch #6
I just picked up my TS1910 today and watched them install the PTO clutch. It took about 5 minutes to install, probably about the same to remove. Can't wait to get home and try this thing out.
Alex
   / pto clutch
Thanks for the advice guys. I have now bought myself an over running clutch with quick release and it has made my work faster and the tractor safer to use. It cost me €125 so wasn't cheap but i think it was worth it. once again thanks for the help.
   / pto clutch
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
1274 (A50490)
1274 (A50490)
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
1998 FORD CRANE (A52472)
1998 FORD CRANE...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
