Redfred1
Started a thread and couldn't find it; so I will ask again. I have two different problems. First I have found that the shear pin on the mower deck driveshaft is broke. I've used PB Blaster to get it to move and now it is stuck. Could I just drill another hole for a bolt? Don't really want to hit the yoke that hard; But? Question 2. How can tell if the PTO clutch is bad? It worked erratically Sometimes it would work fine; other times it would start; then slow down when under a load. Right now; the inner shaft on the tractor turns normally; but the outer part won't. It was brought back to me this way; I don't remember hitting anything with the mower deck. Any suggestions would be appreciated. RF
