PTO Clutch Brake Adjustment (Ford 5000)
   / PTO Clutch Brake Adjustment (Ford 5000) #1
browndd1
Hello,
When I disengage my pto lever the pto still turns. I am assuming the brake band is wore out but not for sure. Does anyone know if the screw on the left hand side of the tractor with a nut is how you apply tension to the brake band on a Ford 5000 diesel tractor? Also, how do you get the clutch pack loose from the tractor after you take the back cover off and pull out the shaft?
2008 John Deere 608C combine head (A50657)
2008 John Deere...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2017 UTILITY 102" X 53' VAN TRAILER (A51247)
2017 UTILITY 102"...
UNUSED FUTURE STP45 HYD BREAKER HAMMER (A51248)
UNUSED FUTURE...
