Chipper PTO Chipper Does Not Lift High Enough
   / PTO Chipper Does Not Lift High Enough #1
JLD
Pittsboro, NC
Kubota 2410
My 3PH does not lift my PTO chipper high enough. With uneven and rocky ground it sometimes scrapes. Can anyone recommend an off the shelf modification to get it higher (a few inches would help). I realize that it will raise the center of gravity of the tractor, but I would rather not scrape.
   / PTO Chipper Does Not Lift High Enough #3
</font><font color="blue" class="small">( shorten the top link sometimes this gives you a better departure angle )</font>
Just what I was going to say, If you have it all the way in now you can buy a shorter one (about 20 bucks ) and leave it attached to the chipper when you take it off.
Shortening the top link does not buy me much, But it just occurred to me that I can replace the fixed length lift arm with another one that is adjustable, screw both sides tight, and get the few inches I need. Thanks for getting my brain in gear.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
LOOK! (A53485)
LOOK! (A53485)
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2013 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
1991 Cummins NT-855-G5 250kW 3-Phase Diesel Generator (A55851)
1991 Cummins...
