PTO bushhog shaft wobble ?
   / PTO bushhog shaft wobble ? #1
sailorman
Platinum Member
Southeast La.
Kubota 2320
Unhooked bush hog this a.m. to do other work. I noticed when sliding the shaft and working it side to side a bit that I have a very slight side to side wobble ( less than 1/8 ") . Most pronounced at longer shaft position. Non-existent at shortest shaft position. Shaft doesn 't look damaged in any way. Is this normal ?
   / PTO bushhog shaft wobble ? #2
The two sliding sections of the shaft have a pretty loose slip fit. You don't have a problem.
   / PTO bushhog shaft wobble ? #3
As Roy said, I would not worry about that tiny bit of wobble. When you have to start worrying is when it looks like a jump rope being swung by two little girls on a playground. I destroyed one on my old Ford Jubilee by raising the 3PH too high and bending the shaft with the front lip of the cutter. When I started the PTO, it was awful.:eek:
Thanks guys for the answers. It was just what I wanted to hear !! Ended up doin' 3 hrs. of bush hoggin' today and all went well.
   / PTO bushhog shaft wobble ? #5
As the others have said , it should be OK (as long as you know for a fact that the shaft has not been cut too short and that there is enough engagement when fully extended) .
1275 (A50490)
1275 (A50490)
2002 PETERBILT 330 CARGO TRUCK (A50854)
2002 PETERBILT 330...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2017 SANY SY365C LC EXCAVATOR (A51242)
2017 SANY SY365C...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Ford Super Duty Pickup Truck Bed (A49461)
Ford Super Duty...
