patrickg
Veteran Member
I wasn't sure where this belonged...
Anyone ever hear of powering a band mill either from the tractor's PTO, accessory hydraulics, or both?
I was wondering about the efficacy of using the tractor's rear remote hydraulics to power a couple reversible hydraulic motors to 1. raise/lower the cutting head and 2. drive the cutting head down the cant (and back.)
AND... use the PTO to power the blade. My Kubota (L-4610) runs up near redline to make 540 RPM. Since I don't need the full HP (or like to run high revs if I don't have to) I thought I could run a jack shaft as a speed increaser and maybe get 540 RPM out of the PTO connection at something like 1800 RPM.
I think you'd want to be on the high side of the peak torque RPM so it would "stiffen" when loaded. I think I would only need to develop about 10 HP to do OK. The largest engine I have seen on a hobby size mill is a 20 HP Kohler twin. Since I have 40 HP available at the PTO I won't be straining the tractor.
Comments?
/forums/images/graemlins/smile.gifPat /forums/images/graemlins/smile.gif
Comments?
