PTO Backhoe Conversion? Please Help!
   / PTO Backhoe Conversion? Please Help! #1
waggy5
New York
Kubota M7040 & B2320
Hi, I would like to convert a 3 pt backhoe that operates off a PTO pump to operate off my tractor remotes. Any suggestions? Thanks........
   / PTO Backhoe Conversion? Please Help! #2
How many GPM does you BH require? Does your tractor produce that GPM. Do you have remotes installed now?
   / PTO Backhoe Conversion? Please Help! #3
I just answered your other post, Please do not double-post your question-it makes it very hard to help you when answers to questions are scattered between different forums.
My tractor has 16.1 gpm flow rate and has two (2) sets of remotes. I do not know the flow rate of the BH. The BH was once mounted to a large flat-bed truck. It weights about 1 ton. 12.5' reach.
   / PTO Backhoe Conversion? Please Help! #5
The 16 GPM is plenty, in fact your hoe will be faster than you may want. If so, just reduce rpm.
Hi, I am fairly new to posting and the correct "ways" to post questions; but anyways, I am trying to figure out if I have to do any type of work to the existing valve system on the backhoe that goes to the operating levers. I have hooked into one set of remotes and "opened" my hydraulics to allow fluid to flow into the BH valve. When I do this the system will not allow fluid back to the tractor and dead-ends. After blowing one of the lines I new something was not quite right, so before I go any further I was looking for help and new by browsing the vast knowledge here on the net I would get some great advice. Thanks. When I hook up my Split-Fire woodsplitter in the same maner the fluid flows back and forth properly. By the way, the Split-Fire is one heck of a machine! I modified mine by adding 4" to the top and replacing the far end with a heavier end with "wings" to aid in the spliting function. I am able to split up to 4 cords per hour with the help of two other people.
   / PTO Backhoe Conversion? Please Help! #7
When you say, open the hydraulics, what did you mean? Did you bungee the lever open?
I believe the return from the BH should go to reservoir.
Check your QD's also.
   / PTO Backhoe Conversion? Please Help! #8
Are you trying to put a closed center BH on a open center tractor?
1) I use a bungee-cord to hold the lever open which allows the hyrdaulic fluid to flow to the BH, wood splitter, etc...
2) The tractor has open center hydraulics,
3) I am reseraching the net to try and find info on the BH. I will post as soon as I can find out anything.
4) I was looking at feeding the BH with one remote and planning on running the return line from this remote directly into the tractor housing/sump?
Does this sound correct?
   / PTO Backhoe Conversion? Please Help! #10
I'm willing to speculate as much as the next guy.
If you bungee a remote open for a splitter, it should work the same for your backhoe. Just plug the return from the backhoe into the other quick connect just like you did with your splitter.
2604 (A49346)
2604 (A49346)
2015 Toyota Prius Hybrid Hatchback (A46684)
2015 Toyota Prius...
Lockwood 30”x11’ Stinger Conveyor (A47369)
Lockwood 30”x11’...
International 8460 Round Baler (A49251)
International 8460...
Raccoon RC-G4.0 Golf Cart (A49251)
Raccoon RC-G4.0...
2014 Bandit 4000T Foresty Mulcher (A47371)
2014 Bandit 4000T...
