Trev
Platinum Member
- Joined
- May 24, 2002
- Messages
- 918
- Location
- Williamson, NY (near Rochester)
- Tractor
- Currently tractor-less
This is going to be controversial, and I want to preface this by saying that what I'm about to talk about is almost certainly a dumb idea.. please, nobody try this at home!!
I was hooking up my finish mower the other day, and the PTO shaft wouldn't slip into place. What I finally did was leave the engine idling, and move the PTO lever slightly.. then go back and see if it would slip on. I had to do this about five times before the splines aligned properly to allow it to slide on.
I was careful to make sure no part of my body was near anything around the blades or the shaft, just in case.. for whatever reason, the PTO started to rotate. I just held the shaft gently, pulled back the sleeve, and tried to push it on. When it didn't go, I would go up, engage the PTO for a second to rotate the shaft, and then disengage it again and go back to the mower to see if it would slide on.
Is this utterly stupid? It didn't seem to me that I was at great risk. If the shaft had started to rotate, it would have just spun in my hands and I would have let go and shut her down.
What do you guys think? Is there some other way of getting the splines to line up without having to do things like shut the engine down, reach under the mower and rotate the blades by hand, try to get it on, and repeat until it works?
If one is careful, is it really essential to shut down the engine?
