PTO and/or tiller issue
/ PTO and/or tiller issue #1
andythomasday
Edwardsville, IL
none
Hey all,
I have a l2650 4x4 and I just put a new 4' king kutter tiller on it today. Everything works fine until I raise the tiller while it's running. I've done this before on other tractors with no problems. When I do it it's really jerky. Lowering the tiller doesn't cause any problems. I've tried fiddling with the hydraulics valve beneath te seat and it hasn't changed the jerkiness. I also notice that when I put the hydraulics lever all the way down while tilling I can move it almost halfway up with no upward movement of the tiller. The upper half of the lever distance moves the tiller at a steady, jerky rate. I don't notice the jerkiness with a blade but there isn't a pto running. Maybe the pto shaft from the tiller to pto isn't lubed well enough. Although I thought I put enough on there. What do you think?
Also, this tractor doesn't have live pto.
/ PTO and/or tiller issue #2
I'd check that the PTO shaft isn't too long, sounds like it's binding up as you raise it. Turn tractor off, raise it all the way, and see if there's any slack when you try to disconnect the PTO shaft.
/ PTO and/or tiller issue #3
I'm with Beezfun, on this.
/ PTO and/or tiller issue #4
Mine is similar. I don't have the jerkiness when I raise it up. But it does have a "delay" when I go to raise it while it is running. It is not like this when I use a blade. Instant lift. I figured it was the weight of the tiller. But not sure.
/ PTO and/or tiller issue #5
Sounds like too long driveshaft or the ujoints are in a bind because they are being moved too far (too great an angle).
The lift is slow because u are lowering lever further than arms are going. So fluid had to fill cylinders back up. There's no point in pushing the lever down further than arms are dropping.
Make sure u grease the tiller and that both gearboxes are properly filled with good clean gear oil.
Have fun!
/ PTO and/or tiller issue #6
Ujoint are in too much of a bind. (too much angle) Just dont raise it all the way.
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2010 Ford Crown Victoria Sedan (A61574)
2010 Ford Crown...
2016 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2016 VOLVO VNL 6X4...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
