PTO= 540rpms
   / PTO= 540rpms #1
GolfGolf
The River Valley (Arkansas)
Farmtrac 535
Farntrac 535 King Kutter bush Hog
According to my operator's manual it says to rev up the engine to 1800 rpms before engaging the PTO.
Does this mean I need to operate the tractor at 1800 the entire time I am using my bush hog (or anything else utilizing the PTO)?
I know this may seem a silly question to all you oldtimers but I am trying to understand this machine.
I need to put the tractor into a lower gear so that I don't go too fast while using the bush hog.
Gary
   / PTO= 540rpms #2
They probably advise revving to 1800 rpm when engaging the PTO to keep the engine from dying from the load. I generally have to rev my engine to about 1500 rpm to keep the PTO from killing it. THEN I rev it up to the indicated PTO speed, which on my tractor is about 3,000 rpm, before actually using the bush hog. Otherwise, your engine won't have enough hp to overcome a sudden severe load, or you won't be able to go very fast while bush hogging. You also run the risk of not having enough oil flow to the engine bearings. This will cause them to prematurely fail.
Ralph
   / PTO= 540rpms #3
Yes, you need to maintain RPM's that put you around the 540 PTO speed. You don't have to be exact, but should be close.
   / PTO= 540rpms #4
I only engage the PTO at idle to reduce shock loads to tractors and equipment. Then rev tractor to RPMs needed to run equipment. Personally, I rarely have to run at "PTO speed" to get desired results. Your results may vary....
   / PTO= 540rpms #5
You want to feather in the implement, or you can do damage to the PTO. I don't know the type of PTO in your tractor, but the lowest speed that does not kill the engine is the easiest on the mechanism. Then slowly increase the engine rpm until the 540 pto speed is reached. That speed is normally marked on the tachometer with a line, arrow or even "540" or "PTO".
jb
   / PTO= 540rpms #6
Gary
What's the engine rpm that's required to produce 540 rpm at the pto?
For example, my Mahindra 5525 (54 hp engine, 45 hp pto) produces 540 pto rpm at 2060 engine rpm.
When I use my 6-ft Hawkline brush hog, I engage the pto clutch with the engine at 1300 rpm or so and then rev up to 2060 rpm if I want to run the mower at 540 pto rpm.
   / PTO= 540rpms #7
Gary, I"m not sure what type of PTO the Farmtrac has. Is it electrically engaged with a switch or mechanically engaged with a lever? Is it an independent PTO that operates whether the clutch is depressed or not? Can you engage the PTO with the clutch depressed and then slowly release your clutch?
There are several different types of PTOs and knowing exactly what type your Farmtrac has is important for the best answer.
   / PTO= 540rpms #8
I second this approach and is how I've done things for yrs.
   / PTO= 540rpms #9
Ralph
Not enough oil to the engine bearings? I was under the impression the oil pump provided enough pressure/flow throughout it's rpm range. Do I need to maintain a minimum rpm even when just idling? I would hate to lose my first tractor/favorite toy!
   / PTO= 540rpms #10
spaceman,
it is never good to overload a deisel engine. engines produce more hp the faster they turn. your tractor will only produce its rated HP at its rated PTO speed. if what you are doing for work requires less than full HP you can run your engine slower. for instance you are doing virtually no work when idleing therefore you need little HP.
Chris
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2014 KENWORTH T800 (A53843)
2014 KENWORTH T800...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
