PT1418 won't start but clicks...ideas?
   / PT1418 won't start but clicks...ideas? #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
PT1418 won\'t start but clicks...ideas?
Hey guys:
My old PT-1418 is acting up right now. This is equivelant to the PT-180 (18hp Briggs and Stratton engine), but it's 15 years old now, and still running strong...usually!
Anyway, when I try to start it, it either clicks or does nothing. I've hooked a jumper battery to it and same thing. I'm pretty sure the battery is not dead (fan comes on when I turn the ignition switch on...I re-wired it that way a while back). I had the same thing happen last week, and it was a short. I had been ramming into some dirt piles and had caused the battery to slide forward just enough for the positive lead connection to touch the engine, thus the short. I fixed that and that's not the case this time.
I thought it might be the solenoid switch, so I tried putting a screwdriver across the poles from battery and starter, but no dice. I wonder if the ignition switch could cause this? I seem to have to replace the ignition switch once per year.
I'm hoping this isn't some strange short somewhere obscure, or the starter going bad (requires the engine to be pulled out to replace the starter). I've committed to a church project Saturday, and I need to get this sucker cranking again quickly.
Any ideas?
TIA,
Dave
   / PT1418 won't start but clicks...ideas? #2
Re: PT1418 won\'t start but clicks...ideas?
Dave:
The short may be a clue. Depending on how the contact occurred, part of a wire may have been fried. If the battery wires are old, replacing them and making sure the ends are clean and tight may solve the problem.
I can't count the times that I've chased obscure electrical gremlins to find that it is a bad ground all along. If you don't replace the wires, check both ends of both wires to the battery, particulalarly the negative, to make sure the contact surfaces are clean and bright, and the clamps/bolts are tight. I use a wire cup brush in a portable drill. If that doesn't do it, work toward the starter, one connection at a time, taking apart, cleaning and reassembling tight.. The ends of ground wires to the engine and engine to frame often fail due to a little corrosion.
I worked through a similar problem with Bubenberg and his skid steer recently. (He will say I was little help.) After we disassembled the switch panel, and unsuccessfully chased all over the wiring with a meter, in windy bitter cold, he cured it by replacing both battery wires. We'll never know, or care, whether the problem was actually the wires, or just the connections.
Well, I just managed to go check the battery, and it was completely dead. So, perhaps the battery is just shot, or there's a short that's killing the battery. I got it cranked with a jumper battery, and parked it in the garage. It's hooked up to a battery charger right now. I was charging at 10 amps, but I noticed the battery is dripping some fluid and bubbling, so I turned it down to the 2 amp setting. I'm thinking the battery is shot, and I'm going to try putting a new battery in first. I'll definitely be taking the jumper battery with me this weekend...maybe the charger/starter too!
Dave
   / PT1418 won't start but clicks...ideas? #4
<font color="red">perhaps the battery is just shot </font>
Sounds like it. [I'll resist the temptation to edit that back into my prior post.} /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / PT1418 won't start but clicks...ideas? #5
</font><font color="blue" class="small">( Anyway, when I try to start it, it either clicks or does nothing )</font>
Ahhhh...the dreaded "click" of a dead battery. Looks like you found your gremlin.
   / PT1418 won't start but clicks...ideas? #6
</font><font color="blue" class="small">( I'm thinking the battery is shot, and I'm going to try putting a new battery in first. I'll definitely be taking the jumper battery with me this weekend...maybe the charger/starter too!
)</font>
If the battery is leaking then it is shot. But I think the source of your problem is more likely to be the starter. The clicking you hear is probably the solenoid. If you don't hear clicking, then you can blame the battery.
Ok, an update here. I installed a new battery, no dice. I pulled the solenoid and installed a new one, no dice. I thought I had found a short in the lead from the solenoid to the starter, so I took it off and cleaned and checked it, and put it back on tightly with good connections and routed away from the engine as much as possible, no dice. I pulled the ignition switch and checked that the starter pole consistently had a voltage when the key was in the start position, looks fine. Still wouldn't start...either clicked or nothing. I finally gave up for the night and put the hood/gas tank back on (on my old model you have to take the hood off to replace the battery...what were they thinking???)...decided to give it one more try with the jumper battery...it started! In fact, I removed the jumper battery and it started 5-6 times in a row. Go figure.
It must indeed be the starter. I'm not looking forward to that one...the starter is on the bottom of the engine, and I don't believe it can be taken off without pulling the engine out! Fun, fun, fun...
Dave
   / PT1418 won't start but clicks...ideas? #8
OK - I'll go out on a limb and bet it isn't the starter. When starters are intermittent, usually it is when they stop in one spot where bad internal contacts or a winding don't work. A jumper battery should not make a difference.
I still suspect battery wires and the connections at each end. New wires should be easier than the starter, so worth a try?
   / PT1418 won't start but clicks...ideas? #9
</font><font color="blue" class="small">( ONew wires should be easier than the starter, so worth a try?
)</font>
I agree with that opinion. Perhaps it might be a loose or corroded ground somewhere too since it is a much older machine.
Well, it seems to be cranking reliably now. Either it was the solenoid exhibiting intermittent behavior, or cleaning the contacts, etc., did the trick. Perhaps it just needed a more TLC since I was beating it pretty hard last week!
Thanks for the help guys!
Dave
Thought I'd add an update here. In thinking this over, I'll bet the electrical cable going from the solenoid to the starter had a loose connection on the starter. It was so gunked up with grease and dirt that I didn't notice if it was loose or not, but I do recall that the 2nd nut on it was loose after I had taken the cable off. That would certainly explain the intermittent-ness (sp?) of this problem. It started fine about 10 times today...let's hope it does the same tomorrow!
L8r,
Dave
I forgot to come back and post the result here. Turns out the problem was a corroded ground cable from the battery to the frame! I took it off and I could see where it had arc'ed against the body. I cleaned it with a wire brush, and it's started right up with no issues since. I'm sure this will rear it's ugly head again since the connector on the cable was pretty corroded, so I picked up a new ground cable and copper bolt, which I'll put on it this weekend...$6 of preventative maintenance sounds like a good choice to me. /forums/images/graemlins/cool.gif Sometimes it's the simplest things, eh?
Ya know, this old machine was pretty beat up and had oil leaks all over the place when I first got it...I've done so much work to it that it's in remarkably good shape now. I have learned more about hydraulics than I ever could have imagined I'd need or want to know! Anyway, the fact that this machine is 15 years old (serial# 158!...but it did get a new engine in 2000 or 2001) and still running strong ought to be quite a testament to the longevity of the newer machines most of you folks have (although mine does take more maintenance because of it's age, or that's my impression anyway). I've dug out medium size stumps and pipe trenches with the front hoe, I've moved literally tons of sand, rock, dirt, mulch, etc., and it'll still pull a trailer loaded with 2000+ lbs of sand into my backyard without any grunting or stumbling. Pretty amazingly powerful for it's size and weight. I can't imagine why anyone would go buy something like a Toro Dingo or one of the clones for $15-20K (which is very similar mechanically, and can do lots of the same work, but can't do it nearly as well and can't do it without tearing up turf!) versus just buying a Power-trac, except for maybe really needing the 3' wide size of a Dingo/clone. Anyway, just my musings...
Dave
   / PT1418 won't start but clicks...ideas? #12
<font color="red"> Turns out the problem was a corroded ground cable from the battery to the frame! </font>
Great news, not only that it ultimately was an inexpensive fix, but that I guessed right. Forecloses Fourteen's opportunity to propose that the first troubleshooting step for intermittent starting should be to reverse the wheels. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
LOL! I should've known to listen to Charlie in the first place...what was I thinking? /forums/images/graemlins/tongue.gif
   / PT1418 won't start but clicks...ideas? #14
The gnarly beast rides again! Yee haa!!!
Hi, Dave. /forums/images/graemlins/wink.gif
   / PT1418 won't start but clicks...ideas? #15
</font><font color="blue" class="small">( Turns out the problem was a corroded ground cable )</font>
<font color="red"> Your best friend here is a tube of GE Silicon Rubber Caulk!
Remove the battery cables. Clean any rust, corrosion, and lead oxide off with a knife and wire brush. Flush with Baking Soda water to neutralize any acid. Dry. Coat all bare metal, including the battery posts and cable ends, inside and out, with Silicon Rubber. Reassemble while still wet.
We used to coat battery posts and cable ends with Vaseline, but the Silicon Rubber lasts much longer.
PS: The best way to spread Silicon Rubber to a nice smooth finish is with spit on a finger. Not water - spit!
PPS: If you haven't done so already, consider reversing your wheels! </font>
   / PT1418 won't start but clicks...ideas? #16
Hey 14, whats the thing with reversing the wheels? never heard of this before. /forums/images/graemlins/grin.gif
PJ
   / PT1418 won't start but clicks...ideas? #17
</font><font color="blue" class="small">( never heard of this before. /forums/images/graemlins/grin.gif
PJ )</font>
<font color="red"> Sorry to hear that!! /forums/images/graemlins/shocked.gif Maybe I'll post a little something about it sometime!! /forums/images/graemlins/smirk.gif </font>
WACKER NEUSON EZ26 EXCAVATOR (A60429)
WACKER NEUSON EZ26...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
BOBCAT MULCHING HEAD (A60429)
BOBCAT MULCHING...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
