PT vs Composite Deck
   / PT vs Composite Deck #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
Looking for opinions on using PT versus composite/man made material for a deck. The up charge for composite/man made is 60% - 70% but the contractors I've talked to both made the same comments.
- Composite/man-made lasts longer with very little maintenance and comes with a 25 year warranty.
- Today's PT is nothing like it used to be (since CCA was banned)
- Today's PT decking checks, twists and warps much more than composite/man-made.
Does anyone have experience with either material?
Is composite (Tamko) worth it?
   / PT vs Composite Deck #2
Go with the composit, especially if it's in the sun. I bought the best PT 5/1/4 boards that I could find 4 years ago when i built my deck. the boars are cracking and splintering. I clean and re-stain every year. The deck on my old house using older PT 15 years ago and still looks like new, although it is under roof. The wood today is noting but pure garbage.I'm going to be replacing my floor with Trex or some kind of composite this summer.
Just don't understand the premium for ground up coke bottles and saw dust...Price of progreess I guess.
   / PT vs Composite Deck #3
Mike, I've had TREX composite decking at our lake home for about 6 years now...I would think that after about 4-5 years the initial premium is made up for in the lack of cost of maintenance...we even have it on the dock at the boathouse where it should show any shortcomings in that environment as it is practically always wet and in the hot summer sun...I've had no problems whatsoever with maintenance, cleaning or anything else for that matter...and when barefoot, no splinters! I would highly recommend it. It is also very resilient and the color goes all the way through the product...yeah, I've dropped a tool or two on it and it is no worse for wear. If you can afford the premium it brings up front, you'll be very happy with it in the long run.
   / PT vs Composite Deck #4
I built a large (12x30) deck on the south side of my house 5 years ago with Portico composite decking and even with the years of sun, NH winters, 2 young kids, and a grill complete with grease and dropped food, it still looks like new. All I do is power-wash it in the Spring then again in the Fall with NO cleaners at all, just high pressure water. It doesn't even look like the gray color has faded much at all. I also used the Tiger Claw deck fasteners so there are no screws showing and it was a little tougher to install but looks tons better.
   / PT vs Composite Deck #5
The absolute best decking materials to use is the IPE decking, I have built many decks from this and they last 4-ever if properly maintained with recommended oil stain, although not cheap at $3.00 + ln ft. you can get it in many widths, and it is only 3/4 inch thick but will hold equal to a 2" thick board,..................... I have customers spend 10K on just the decking boards alone, this isn't including the framing material cost, But they enjoy using their decks not having to keep waterproofing pressure washing ect.etc..
Trex is the 2nd best way to go, although it is not entirely maintenance free, there was mention of sun and using of the Trex instead of PT materials, Trex is pre-colored in the composite of materials it's made from and these materials can and will fade under extreme hot sun, I had a customer ask that I replace the trex on his deck because he didn't like that it had turned a Grey/white color,from originally red. I explain to him that the direct hot sun will take a tole on anything he used, I then ask that he let me pressure wash the deck as first option and to try something I have heard about, Using liquid wax to re-seal the composite materials, Not water sealer... but wax,,,, after doing this he was very pleased and decided to leave the Trex down, I told him he should have it lightly pressure washed every other year, this was 3 years ago and have not heard back from him, the deck is now 6 years old,........ and also if you use the clips method then you will not have any visible screws/nails, although the nails from the underside that holds the clips in place will need to be checked from time to time as the frame wood starts to age and shrink the nails tend to loose their bite,
   / PT vs Composite Deck #6
We used both PT and composite materials building a public playground a few years ago. The composite stuff takes a bit longer to cut because it's thicker and more dense. Predrilling is needed. Screw heads won't compress and sink down like with PT. I'm not sure how you'd ever really wear it out unless it degrades in sunlight. Dimensionally, it appears to be a bit different iin size than standard lumber.
If it weren't for the cost differential, I doubt you'd see many PT decks. My PT deck needs to be restained only after a few years, and I'm seeing the cracking and so forth others have mentioned. The new PT would be corrosive to fastners, too.
   / PT vs Composite Deck #8
I have decks that were old PT,new PT and solid vinyl. While expensive the vinyl is far superior to the PT. Colour is all the way through so no issue that way and does not warp or check or destroy fasteners etc. If under cover, I found the PT stands up very well but if fully exposed to the elements it seems to last about 10 years structurally but less appearance wise (no stain) . I looked at composite systems like Trex but liked the look of the vinyl -- JMHO
   / PT vs Composite Deck #9
+1 on the Ipe wood. Our wrap around deck is made of Ipe. It is extremely hard and heavy. A little hard to work with though and like deepndirt said it is a little pricey.
A side question to deepndirt. What brand stain do you recommend?
Sorry for the aside Mike.
Mark
   / PT vs Composite Deck #10
...Predrilling is needed. Screw heads won't compress and sink down like with PT. ...
I used composite decking on a northwest facing porch that almost never sees sun, so it would be a moss factory if I used real wood. Anyway, they make special screws for the composite decking that will pull into the material, so you don't have to pre-drill the holes.
The PT decking I put on the south side of the house, under a roof, has been trouble. One twelve foot board shrunk THREE INCHES and split the screws out of the joist. When the PT breaks down to the point of needing to be replaced (two-four years?) I'll go redwood or composite.
-rus-
2018 Dodge Charger Sedan (A55758)
2018 Dodge Charger...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
2014 Haulmark Box Trailer (TITLE) (A50775)
2014 Haulmark Box...
