PT repaired!
   / PT repaired! #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Finally. Total bill $890. Ouch. They replaced the wiring harness, magneto, flywheel windings, engine/pump coupler, and a seal in the hydrostatic drive pump. I'm hoping I won't have any more problems for quite a while.
I guess I can't complain. I knew this guy needed quite a bit of refurbishment when I bought it. I'll pick it up over lunch tommorrow...
Dave
   / PT repaired! #2
Ouch!! /w3tcompact/icons/sad.gif Glad to hear it's done, though. Sounds like they did some things that couldn't have happened without taking the engine out.
   / PT repaired! #3
Was wondering where you have been. Your PT has been gone for some time now but looks like it should be ready for the winter work load.
Will be interested to hear of its performance.
PJ
   / PT repaired!
I was wishing I had it back late last week...we had an ice storm (ie. freezing rain) that took down trees (and power lines along with it) Wednesday. Would've been useful for moving the pine that fell on the corner of my workshop.../w3tcompact/icons/smile.gif.
Dave
   / PT repaired! #5
Glad it's back home where it belongs and is appreciated.../w3tcompact/icons/smile.gif
That pain in your wallet, however, will subside in a couple of weeks, quickened only by more seat time./w3tcompact/icons/smile.gif
   / PT repaired! #6
Dave,
If we could attach sound clips, I'd hook you up with the Halelujah chorus (I know I can't spell).
Glad to hear the tractor is back in action
   / PT repaired! #7
good luck .... glad you have your machine back
   / PT repaired! #8
Congrats! Glad you are back in action. What's next on the project list?
   / PT repaired!
Weekend...
Well, I ran the DOT over the weekend to cleanup some tree mess from our recent ice storm. After about 15 minutes of run time, it started dumping oil. I started troubleshooting, and found a hose that these yahoo's had only finger-tightened. I put a wrench to it, and that fixed that problem (after probably 1/2 gallon of oil!). Then I just happen to notice that the hour meter showed 105 hours. Strange since it showed 30 hours when I picked it up from the repair shop. (I know what you're going to say. The original hour meter wasn't working, so I replaced it, that's why the hours are so low.../w3tcompact/icons/smile.gif). Anyway, these boneheads wired the hour-meter directly to the battery lead. The hour meter runs while the machine is on or off! (And drains the battery, incidentally.) I unplugged it for now, but I can rewire it easy enough. The hose I could understand easily overlooking, but I was a bit unpleasantly surprised that they wired the hour meter incorrectly, especially since they replaced the wiring harness and knew exactly where every wire went. Duh. Needless to say, I called the repair shop this morning and gave the supervisor some calm but firm "constructive feedback".
The good news is that, after this troubleshooting, it ran well with no mishaps until I ran it completely out of gas!
Dave
2006 Ford F-150 Pickup Truck (A50860)
2006 Ford F-150...
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
2018 GMC Sierra 1500 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
