Snow Attachments PT board as snow blade edge?
   / PT board as snow blade edge? #1
jdgreg
Warrenton, Va
I could swear this has already been discussed here, but my searches didnt show anything, so sorry if this has already been beat to death. But I was thinking about replacing my JD FEL snow blade edge with a pressure treated board. I wanted to try this first to see how it worked rather than getting an expensive poly board and it wind up not working well. I have 2-3 driveways in my subdivision that I help out plowing, all paved asphalt but one, and the common driveway is chip-n-tar. The common driveway makes me hesitate on spending for a poly board until I see if the concept would work on a chip-n-tar surface, and how long it would last, by using a PT board first.
I tried the horse stall mat route on my BB, but that didnt work very well. The mat probably was not thick enough.
   / PT board as snow blade edge? #4
it would work but for a short time. the dimensional boards just wears out too quickly. there is no point using PT. I built a poor man's snow pusher for my BX24 out of 2X12's . The bottom corner has worn away in less then one plowing season,so i had to add on a 2X6 for a throw away wear edge.
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
