PT Augers in prairie clay
   / PT Augers in prairie clay #1
Locomotive8
AL
2002 Bobcat Toolcat
Hey guys,
I have been following this discussion board for quite some time and am getting very close to a PT purchase. I am looking at the 422 and 425 and very possibly the 1430 if I have to. I live in an area of the country with "prairie clay" or thick white dense clay that is no fun to dig with a shovel. I would like to use a plant head auger (30 inch) and was curious if anyone has tried this and what the results were. I am afraid that the machines GPM will not be up to the task but I just wanted to get some expert opinions.
Thanks so much for the info and I love seeing the pictures and stories posted of your PTs.
   / PT Augers in prairie clay #2
My thought on this is that the tip that comes on the PT auger isn't really optimized for clay. It is a rounded tip, which I think wouldn't allow you to push deep enough into the clay for the auger blades to start working. I have seen some other auger tips that I think would work better, but I don't know if anyone makes one that is a bolt on replacement for PT's stock tip.
Below is a picture of the standard groundhog auger tip vs the power-trac version:
   / PT Augers in prairie clay #3
Tim might be right that an aggressive tip may make the start of a hole a bit quicker, but I've had pretty good luck with the PT auger in dry hardpack and in thoroughly frozen ground. I replaced one post in 15 degree weather, through a foot or so of frozen ground. (1845 with 12" auger).
The real difference between the PT system and a 3-point is the down pressure. Without a special kit, 3-point systems rely only on the weight of the digger. Even in hard pack, I have consistently found that the PT puts enough down pressure to get the auger started. I have no experience with the bigger augers, however, which certainly will require more power than my posthole setup.
Big auger users, please chime in.
   / PT Augers in prairie clay #4
I have a 6" auger and a 12" auger and hard Red Clay. I use the large one to plant small trees and shrubs, the smaller one for fence posts. I can dig with either one of them without any problems. I can't dig 6 inches down with a shovel without hitting the clay, and then the shovel digging stops. I have to agree that the down pressure makes a lot of difference, especially with post holes.
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
FORD COBRA REPLICA RACING CAR (A52576)
FORD COBRA REPLICA...
