PT-425 Middle Joint Question
   / PT-425 Middle Joint Question #1
catsco
Colorado
PT425
Hi all -
Periodically, I've tightened the large nut on the bottom pivot joint, but have occasionally seen play in the top joint.
I can't figure out exactly how it's put together, but tightening the bolt rearward of the pivot that holds the small plate on top seems to stop the play?
Can someone give me insight into how it's put together?
Can't believe that little plate on top is the only "adjustment".
Thanks!
   / PT-425 Middle Joint Question #2
Yours sounds different from mine. Can you post a picture?
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
