Backhoe PT 2445 Backhoe
   / PT 2445 Backhoe #1
jaquetarr
Kerrville TX
PoiwerTrac 2445
What are your experiences with the PowerTrac Back Hoe?
The last backhoe I used was on a Kobota and loved it. Controls were smooth and sensitive. All the valves were tight and the boom stayed put!
With the PT unit the boom drifts down and the boom up is weak. The side to side movement seems pretty limited too.
Enough sad sack, Do I have a bum uint or have others found the PT backhoe to be lacking?
Rgds,
tim
   / PT 2445 Backhoe #2
Have you put a gage in the circuit to see if the pressure is correct. You have to know the pump pressure first as a guide to determine if the pressure is low, to say one, or all of the cylinders. Are you running the engine at max, or idle? Are the front hydraulics the same weak? Are the front and rear hydraulics running off the same pump? Are there any restrictors in the BH circuit?
   / PT 2445 Backhoe
J.J.
To try to answer your many queations:
No gage installed. This is the second time I used the Hoe.
Only the Boom cyl seem to not want to lift. Could be air in the cyl?
Running the Eng at mid range, again the bucket and jib booms are good
Front Hyd are good w/ no problems on the tiller
I believe the 2445 has a two stage pump. There is no hyd diagram in the manual (previously discussed at length on this BBS) so my remark is from observation.
Do not know of / cannot see any restrictions such as pinched hose. The back hyd switch is in the full 'on' position.
I'm not asking for troubleshootiing as much as comparitive experience. It could just be that the PT BH has these charesterics when set along side of other Hoes. If everyone has had good performance and I'm the oddball then I'll have to get out the 5 gal bucket & wrenches and start checking things.
I could have a internal leaking control valve that is reducing power. I don't have a ultrasonic tester to listen for fluid bypass and, of course, after awhile everything is hot. With the short time it takes for the BH to drop from full upright to the ground. I suspect a leaky valve. - Maybe a control arm that is not set to neutral from the factory.
Rgds,
tim
   / PT 2445 Backhoe #4
With my 1845, the hydraulic cylinders have drifted down since new. PT stated that was normal. When I was in their showroom, I noted that those implements they wanted to stay up had extra hardware to hold them up.
Sorry, I don't have enough experience with backhoes to compare function, but I think the driftdown does not mean there is a malfunction, just a normal action of the valves PT uses.
   / PT 2445 Backhoe #5
My take on the boom cylinder is if you do have a slug of air on the bottom of the piston,and the cylinder stays vertical for a while, the air will tend to stay there, and will compress to the hydraulic pressure, however, the cylinder will start to operate with hydraulic/air at what ever pressure it takes to lift the boom and whatever you are lifting. If your cylinder is under the boom, you are pushing the boom up. If the cylinder is on top of the boom, you are pulling the boom up. The rod side of the cylinder should be faster, due to less area to fill. If you put the pressure and GPM to that boom up cylinder, it should work as advertise. Perhaps your BH valve is leaking when you go to boom up. A gage, with a tee on the cylinder hose will give you the answer.
If the cylinder has air in it, you need to get the boom cylinder to a horizontal position, and remove the rod end of the cylinder and run the boom cylinder in and out a couple of times.
I just noticed from looking at the pictures of the BH, that the lift up on the boom uses the retract mode of the cylinder, and should be faster than lower boom..
   / PT 2445 Backhoe
Charlie Iliff,
I have a big slab of flat bar on one side of the boom & pins w/ clips to hold it in place. When the unit shipped, it was in place and I've used it to secure the boom when not in service. Glad to hear of your experience. I'll not worry about the drift down and just apply the lock bar.
Aye, Aye Capt J.J., a good place to start to T/S I was digging in mud and the lack of life may have been caused by a suction lock in the mud. The arm was flat out and at the angle there was not much torque force to lift with. It rained all day today so I can't get out to rechek the operation.
Thanks for the advice
Rgds
tim
   / PT 2445 Backhoe #7
I definitely would try the back hoe with near full throttle first and see if that makes a difference.
Ken
   / PT 2445 Backhoe #8
Tim,
Did you ever find out anything about your backhoe. I picked up a used 2430 w/ backhoe, and it's boom up is also very weak and leak down rapid. Thanks.
Reg
   / PT 2445 Backhoe
Tim,
Reg
Guess the problem was getting stuck in the clay mud at a far reach. I worked thru that by curling the bucket first the retracting the boom.
I dug out 18" deep by 26' by 32' patch some of which was breaking out limestone and I did not have any problems. This was dry material. The hoe had enough power to break off all the teeth on an 18" bucket and at times would skid the tractor backwards.
I use the locking bar to keep the boom up and every so often I'll hit the bucket to curl it up and lift the two stabilizer legs as well to keep them from dragging.
The back hoe is a pretty good counter weight for the fork lift & bucket with heaping loads. It is serviceable in a basic sort of way. If a person wanted to do a lot of hoe work, I'd recommend looking at another brand with more features.
Rgds,
tim
   / PT 2445 Backhoe #10
Hey Tim,
I've got a 2445 w/backhoe. When I first got it it provided me with an introduction to repacking cylinders. Mine does creep some but does not lack power. Curling and breakout forces are impressive. I think the limiting feature most bothersome is side to side range. It is useful, but I've had it off the tractor for three years and haven't had the burning urge to break it out. I'll generally grab the trencher instead for carving out small holes or such.
1996 International Water Truck with a Caterpillar Engine (A53472)
1996 International...
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2013 HYUNDAI VC2530152 53FT DRY VAN TRAILER (A53426)
2013 HYUNDAI...
378813 (A51573)
378813 (A51573)
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
