PT 1850 Slope Mower - First Impressions
   / PT 1850 Slope Mower - First Impressions #1
wasabi
Platinum Member
Cullowhee Mountain, NC
PT2445 and PT1850
We took delivery of a used PT 1850 last Friday morning. The driver arrived on property at 7:15 am, so I had a full day of good weather ahead. After unloading and scooting around the lawn a bit to make sure the basics were ok, I paid the driver and let him go.
Man am I impressed! For some reason, despite many discussions about wheel sizes, torque and such, I was expecting the unit to be bigger, taller and with wheels comparable to my 2445....not! The wheels are closer in size to our 4x mule than the 2445. The machine hugs the ground like a glove. There is no question that this is one serious machine, but much lower than I thought it would be. I'm six foot and the top of the canopy is about level with me. I'm going to have to remember carefully that the rops is a major head banger. Perhaps stickers of ducks will help remind me....
Between the articulation, oscillation and draft control, it beautifully straddles uneven ground and after getting used to the ride, fairly comfortable. Of course I could not resist a little slope mowing test, so I tackled a lower field of brambles and small locust to see what she would do.
As Carl, Ken and others pointed out, driving takes a bit of mental adjustment. With the double wheels and tendancy to crab crawl and drift, it reminds me more of navigating a power boat than a tractor. It is a bit disconcerting to be positioned so close to the ground and near the wheels, probably just because I'm used to the opposite. Another adjustment was to learn to trust that I could cut close to an object and (assuming reasonably level ground) and the back wheels will follow the track. Though I have many hours on the 2445, the articulation feels quite different and takes some getting used to, especially backing up.
The tilt seat is not exactly smooth, but definately helps. Funny thing was I was on a fairly steep slope sideways and suddenly the seat did not seem to be functioning right. In fact it was trying to pitch me down hill while I "self leveled it" I looked down thinking "what the f$%^, only to discover the bolt that held the seat leveling cylinder had come loose! Glad it was me and not someone else. Easy fix.
Power wise we were most impressed that there is barely a change in the sound of the engine even on steep hills. There is an awesome amount of reserve power to spare and she will climb anywhere I want to go. Figure eights on the hillside were a great way to get the feel of things. This is definately the cat's meow.
Although slightly dirty, the machine is otherwise is fine, but I frankly don't think it had been touched since it left the factory. The dealer I bought it from knew very little about it and I bought it sight unseen. What I thought was a finish mower turned out to be the rough cut which is exactly what we need. Also great news is there are only 112 hours on it! Not so good news included very dull blades (no biggie, but an indication of lack of maintenance), six gallons low on hydraulic oil!, dark oil in the engine (my guess is the oil and filter have not been changed) and need of lubricants. Otherwise, all appears to be well. Mechanically I'm impressed how tight everything is. The hydraulics are ultra responsive, again different for my 2445. Getting the touch just right will take some getting used to.
Started raining the next day....just as well. Before doing anything further I'll go over her with a fine tooth comb...sharpen the blades, change the oil and filters, tighten bolts, grease all zerts, etc....then out to the upper fields to tackle eight acres. Of course it also needs a cup holder and tool box...
All in all I seriously couldn't be more pleased. She will do everything we need her to. Many thanks for all the insights and encouragement that led to this decision.
   / PT 1850 Slope Mower - First Impressions #2
Hey, congratulations! :thumbsup:
There is a huge difference in feel between your two machines, I am guessing, due to the seat being attached to the rear section of your old one and attached to the front section of your new one. It took me a while to get used to my PT425 with the seat on the front section as I was used to articulated machines with the seat on the rear. After a while, it just becomes natural, though.
Enjoy your new machine. Just be careful turning tight around a tree on the upside of a slope. As you probably already know, you can crab downhill and wrap the thing around a tree pretty easily. Solution is to drive around the tree to the downhill side and crab away from it, if possible. Solution B is to get the chainsaw! :laughing:
I hear you Moss. Nice trick about driving to the downside of the tree...thx. makes me think of the roundabouts we have around here...every 90 degrees there is another exit..;)
   / PT 1850 Slope Mower - First Impressions #4
A few notes
Yeah, the seat is jerky, late to operate, but it helps more than it hinders.
My mower blades were dull as well. Remember, Sharp Blades are not wanted on a brush hog. Dull blades keep the stems broken up and less likely to puncture your tires.
PTs mower blades blow. They metal is very soft. Mine were bent up within a few weeks. The "custom" blades I had made are hardened, and while the edges are gone they have not bent at all.
I am very worried about your hydraulic oil level. Please tripple check that you are not leaking anywhere. The 1850 has the most hoses, and leaks happen all over. It arriving 8 Gallons low is bad and confusing.
Tree Wrapping with the 8 wheels happens all the time. I just tree wrapped around a 36" stump. I wish i had taken pictures, but it took a quad with an electric winch to get me out.
I want to ask how much you paid bit I don't think I really want to know. What sort of accessories did you get?
Well, Ken and I have a long list of upgrades for you to do. Let us know when you are ready.
Overheating the engine is an issue with this machine. Probably no different from your PT but.
Oh, what I did was I went and bought some pipe wrap from the hardware store, then got some glue and glued the foam around the ROPS edge. With all the trees and blackberries it tore off after a year, but I am now much more inclined to duck.
Carl
Ps.. Pictures plz
   / PT 1850 Slope Mower - First Impressions #5
Exactly! :thumbsup:
   / PT 1850 Slope Mower - First Impressions #6
I have no place where that work around can be used - it is always solution B, the chain saw, or C, the gas winch
Ken
A few notes
It took six gallons to fill the hydraulic tank. With capacity of eighteen it concernes me as well, but I think I know what happened. The dealer acquired two of these from a bank in Fla. He said repaired a hose in the "steering column" of one of them....my guess is that would be mine. There is NO oil in the tub nor any indication of leakage otherwise. I'll pull the panel to look for signs of the previous leak under the steering wheel. my guess is that is what happened and the dealer was either not concerned or familiar enough to reload hyd fluid.... He was likely unaware of how low the oil was.
I'm ready to learn and willing to tackle whatever it takes to optimize. Download when ready
Good idea....I may do likewise.
Pictures to come...I promise. Left the camera at the farm but my wasabi plantlets arrive tomorrow so I'm headed back up to put them in root cubes and safety of propagation hoop-house.
   / PT 1850 Slope Mower - First Impressions #9
Congrats, Sabi.
Sounds like you got a great deal. I do hope it works out.
-Rob :)
   / PT 1850 Slope Mower - First Impressions #10
Do you ever have those moments when you swear you wrote something and it is not on the board, but you saw it there?
Sabi. I would recommend that you if you have an Iphone or a Droid to look for an inclonometer ap. Both Ken and I have regular inclonometers on our PT (rated to 45 degrees).. Actually ken has 2 but he will explain... It helps you get more comfortable with dealing with the slopes, at least imo. The aps on the phone work pretty well, and you will become very surprised at how less steep you are than you think you are. PT will go practically anywhere it seems.
Hand Truck (A52377)
Hand Truck (A52377)
ATLAS 10 1/2' DISC HARROW (A51247)
ATLAS 10 1/2' DISC...
2013 Nissan Juke Multipurpose Vehicle (MPV) (A51694)
2013 Nissan Juke...
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
