Feb 17, 2004 / PT 180 Aftermarket Oil Cooler #1 C Cub5k Silver Member Joined Jan 31, 2004 Messages 143 Location Maryland Tractor Cub 5252 Has anyone added an oil cooler to the 180? I was told that the mower might give it a hard time in hot weather without the cooler.
Feb 17, 2004 / PT 180 Aftermarket Oil Cooler #2 B blackwell Silver Member Joined Feb 17, 2004 Messages 188 Oil cooler not needed if you use the single blade mower which requires less hp. 3 blade mower eats hp to run belts bearings, etc. I can mow 3 acres in 90 d. temp. non stop. You would be pleased with the 180. Good little machine.
