Comparison PT 1460 traction
   / PT 1460 traction #1
sirmombo
New Berlin, WI
PT 1430
I am considering purchasing a PT 1460 to perform tasks around our horse barn and apple orchard. The apple orchard is on a slope and the ground is often wet when the brush from the pruning has to cleaned up. We have been hiring someone with a skid steer to clean up the brush. There have been a few times when the skid steer got stuck and had to be pulled up the hill.
Would the PT 1460 have similar traction? From the pictures, it looks like the PT may have more aggressive tire tread. Is there any other reason to think the PT may be better?
Thanks for any info,
Bill
   / PT 1460 traction #2
I have a 422 so not in the same league as 1460, but i have used skid steer and i'd think if a skid steer could get around ok, a 1460 should be at least as stable.
   / PT 1460 traction #3
My PT1460 is not as good on slopes as advertised. I put bar tires on it, and it still struggles going up anything steeper than 20 degrees. Problem is that the unit is so darned heavy. The tires will slip, and the tram pump can't pull steep hills. The unit is a fantastic loader, but not such a good mower. It also plows snow pretty well.
   / PT 1460 traction
Thanks for the info,
Our steepest incline is around 14% grade and I was hoping to use it for mowing. Do you think it would have issues?
Thanks,
Bill
   / PT 1460 traction #5
14% grade is only 8 degrees. No problem. Don't bother with the mower. It is lousy at best. I'll give you a good deal on mine if you want it. I mostly use the light material bucket, it can do a lot. I also have the grapple bucket, and it works really well. The plow is good, as is the trencher and tiller. I would recommend getting the mini hoe, that thing comes in really handy.
   / PT 1460 traction #6
I put these tires on my PT. They are mounted on the rims that would normally take the turf tires.
   / PT 1460 traction #7
FWIW: I have a 1445. I routinely mow 20 degree slopes (40%). I have found that adding diamond chains enables me to cross slope mow thistles, which get really slimey. This had caused the 1445 to slide a little (crab) while going cross slope. With the chains it causes less damage to the soil. I use the 72" brush mower to cut bull thistle, and light to medium brush on 20-30 degree slopes. I do mow trimmings, but you don't want to be using a brush cutter within 300' of any building or horse. Perhaps someone with the flail mower can comment on whether the flail mower can mulch tree trimmings. The trend in the commercial orchards out here is to mulch the trimmings and then roto-till them into the ground. The rototiller works great. YMMV.
We routinely use the light material bucket to deliver hay, pick up manure, and spread mulch out on the slopes.
I can't imagine doing it in any other tractor. I don't have lawns, so I am not worried about finish quality of the cut. Unless you need the full lift capacity (height/weight) of the 1460, I would consider the 1445.
I worked on a farm in the driftless area near you, and I would have loved to have a PT then. Someone has a 1850 near you; scan the forum for PT owners.
All the best,
Peter
   / PT 1460 traction #8
I moved 7 cords of wood today, from the wood shed to the back of the house, where it will be burned. I used the 1460 with the light material bucket. I can almost fit 1/4 cord in the bucket, so I made somewhere around 30 trips. In cases like this, I wish it could hold more.
Usually a flail mower is pretty delicate, I would be surprised if it can handle tree trimmings. My mower with the rough cut blades could handle that.
   / PT 1460 traction
The big advantage of a flail mower is that they don't throw rocks and sticks like a rotary mower can. I think that's the main reason they are used around here to mow the sides of roads. I have seen them cut through reebar. It probably depends on what knives it's using. The big disadvantage is the price. They are roughly double the price and require more maintenance.
from what I gathered from this thread, a PT probably doesn't have the traction of a skid steer on tracks, but would be sufficient most of the time.
Bill
   / PT 1460 traction #10
I have an 1850, same engine as the 1460, probably close in weight, but more tires. I second the use of chains. I mow 25 degree slopes all day long, and love the machine. We have clay and it gets really slippery in the winter. But the machine does as advertised.
I would take bulldog up on his offer of the 1460. one heck of a machine.
Mower from PT does a good job of rough cut mowing. No, its not golf course material, but it keeps the grass in the orchard ankle high and that is all that matters to us and our 40 acres. One acre is orchard.
To be clear, there isn't one PT owner here who doesn't hate his machine. They have quirks, kinks, and oddities, but at the end of the day, if you don't need to plow a field, you won't find a better machine IMO. It is a swiss army knife of a machine. Does it all, most of it good, none of it great. My neighbors are constantly at my door to do something that there conventional tractor cannot handle, from getting into stalls (yes, with the 1850 but tires off) to post hold digging on 35 degree slopes (do it all day long).
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53472)
2017 KINZE...
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
