protecting hydraulic hoses $$$
   / protecting hydraulic hoses $$$ #1
MF 1532
Southern Illinois
MASSEY FERGUSON 1532
I make hydraulic hoses at my store . Something I see frequently are hoses that are skinned , chaffed , or mashed . Hoses are expensive and some problems can be prevented . Watch the routing of hoses . Hoses touching each other or touching other things . I take a piece of heater hose the same i.d. as the o.d. of the hydraulic hose , split the heater hose , wrap and cable tie in place . This provides a little extra protection .
   / protecting hydraulic hoses $$$ #2
Probably works fine, but doesn't sound like it looks very neat with the cable ties along the length of a split outside hose.
Maybe either slip the outside hose over the hyd. hose before crimping the end fittings, or use the expandable plastic mesh-like stocking over the hose.
McMaster Carr has the mesh stocking material.
Routing hoses so they cannot become chafed and worn is a good plan too.
   / protecting hydraulic hoses $$$ #3
I have found the grey plastic flexible electrical conduit to work well, too.
If you do not remember to put it on before the hose end fittings, it
can be split with a knife and it grabs the hyd hose really well, without
zip ties.
I have also found chafed leaky hoses INSIDE that mesh that comes with
some factory installations. Outa site, outa mind, I guess.
I did the heater hose on a new tractor fel to protect already assembled hoses , I have the mesh covering for new hoses . The heater hose and u.v. black cable ties are not very noticeable if you take your time measuring , cutting and installing . I am very picky , if it looked bad it wouldn't be on there .
   / protecting hydraulic hoses $$$ #5
I don't like the heater hose idea. You do not want something that is going to hold the moisture and contaminants on to the hose. You want the hose to be able to breathe, unless you have something like 100R18 plastic synflex type. Even the cloth or plastic hose wraps allow the hose to breathe and let moisture out. It's great that you're getting creative, but find something that won't rot the hose out.
   / protecting hydraulic hoses $$$ #6
I had a hose do what Wayne is talking about. Someone thought they would try and relieve the chafing, but they formed a loop at the bottom of the hose, and water got in, the hose rusted and blew out one day.
I recommend spiral wrap.
   / protecting hydraulic hoses $$$ #7
Welcome to the World of Hose Replacements.......Your customers will do everything in their power to blame their worn/taddered leaky hose problems on others......The best way to prevent any and all of this is to install them correctly with proper clearances/lengths and applications in mind and don't abuse the equipment....
If proper installation techniques are followed then they will last for years....IMHO cover materials should only be used for a last ditch effort from external abrasion.......Frame/steel edges should never touch the hoses...
Best thing for you is to keep making them just as the customer wants, the wear and tear on these can be readily installed on the jobsite with abuse.....
back to the drawing board ...
   / protecting hydraulic hoses $$$ #9
Whats wrong with the spiral plastic guard.....little $'y but have never left me disappointed.....no clamps etc....just wrap it around....great for bundling hoses too.....most hydraulic shops have them...
By popular vote on the site , I am re-doing my f.e.l. this morning with the plastic spiral wrap .
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
