Protecting against theft
   / Protecting against theft #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
What can I do that would be easy and within reason, to my 5093E that would make it more difficult to steal?
   / Protecting against theft #2
Lock it in a barn, take out the key, install a hidden battery switch.
   / Protecting against theft #3
leave pto on, remove starter fuse, install battery quick disconnect or for real protection remove one of the wheels
   / Protecting against theft #4
Turn fuel valve to OFF
   / Protecting against theft #5
You'll never stop pros!
But for joy riders possibly the easiest is to cut the starter relay wire and install a hidden switch in that line.
Another would be hidden switch in your seat safety switch wire. (or even pulling one of the wires off of seat switch)
My tractor safety switch was on the H-N-L selector. The selector switch being defective the wires were linked together to start so my hidden safety is to simply disconnect the mated connectors.
How can I find my starter fuse?
   / Protecting against theft #8
How long would it run with fuel valve turned off?
I'll guess 2-3 minutes at the most. You could also remove a frt tire & wheel and take it with you.
   / Protecting against theft #10
fuse should be marked in fuse box if not keep removing one till it won't crank
Four boxes of miscellaneous items (A53117)
Four boxes of...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
eXmark LazerZ Zero Turn Mower (A53117)
eXmark LazerZ Zero...
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
