Pros and Cons of the "open end" drum type augers?
   / Pros and Cons of the "open end" drum type augers? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
   / Pros and Cons of the "open end" drum type augers? #2
One advantage would be for slicing through hard banks or drifts. Closed ends like seen on most American made units you are using the end of the blower as knife.
Is one large auger more efficient than two or three smaller augers?
   / Pros and Cons of the "open end" drum type augers? #3
Hello CalG,
The european snow clearers with you mention have a center bearing support
and huge worm gear reduction gear drive that rotates the two cross augers as one.
Some models are single stage units with a drum auger that has shallow
flighting to a center paddle that ejects the snow out through the
chute and spout.
Hello Oldnslo,
The two and three auger machines are a means to
an end; where they simply convey the deep snow to
the center and then to the impeller.
You still have to crawl with any snow blower that
is a two stage to remove it.
These snow clearers also require a very large amount
of power converted to torque and this requires more
money to make them.
The european market deals with much more snow and
more snow events than we deal with annually as well.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2004 Range Rover HSE SUV (A48082)
2004 Range Rover...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
Miller Bobcat 225G Welder (A49461)
Miller Bobcat 225G...
2010 Ford Crown Victoria Sedan (A48082)
2010 Ford Crown...
2013 PETERBILT 367 DAY CAB (INOPERABLE) (A50854)
2013 PETERBILT 367...
