Pro's and Con's for a 10,000 LB. Dump Trailers.
   / Pro's and Con's for a 10,000 LB. Dump Trailers. #1
JohnBoy45
Tennessee
Kubota L2800DT
Pro\'s and Con\'s for a 10,000 LB. Dump Trailers.
Hi, Does anyone own a Hawke 10,000 lb. Dump Trailer and would this trailer be good to carry a 2300 lb L2800DT-R tractor? What size truck would I need to pull this trailer?
The dump trailer has twin ramps, 15" tires, 2 way tailgate, 5,000 bulldog jack, 2-5/16 A-frame coupler. And costs $4500.00
Thanks, Terry.
   / Pro's and Con's for a 10,000 LB. Dump Trailers. #2
Re: Pro\'s and Con\'s for a 10,000 LB. Dump Trailers.
Anderson has a much stronger trailer for about the same price.
   / Pro's and Con's for a 10,000 LB. Dump Trailers. #3
If you're just using it for carrying the tractor, it would be cheaper (about $1000) to just get a tiltbed trailer. I have one from Cam trailers, after you unlatch the bed, you back up til the bed pivots and touches the ground. No ramps needed.
You also asked about truck size. You said your tractor is 2800lbs, has weight been added to the tires? Does that include weight of attachments? My L3010 goes easily over 4000lbs w/FEL, filled tires, and rake/blade combo. Trailer itself is probably 2500lbs + so you're probably looking at a minimum of approx 6000lbs. towing weight. I would want a 3/4 ton p/u at a minimum. Preferably a One ton dump truck.
Dump trailers are great if you are planning on bulky, light loads and or never leaving pavement. If you are planning on using it for hauling dirt I would strongly recommend against it. With dirt, you can easily end up with more than 10,000lbs in the trailer, the problem here is that there is not comparable weight over the driven wheels on the tow vehicle to give you enough traction to move it as soon as you leave pavement. You'll spend all your time getting the dump trailer and tow vehicle unstuck.
If you buy a big enough truck to pull the dump trailer loaded, you might as well just have the dump bed on the truck. You could use a 3/4 ton p/u with a dump bed insert, or just look for a used one ton dump. The one ton dump can be 2wd, just put a limited slip rear end and traction tires on rear. I would recommend 4wd if you use a 3/4 ton p/u.
What I'm stressing here is that the dump function of the trailer can be seriously limited by other factors.
   / Pro's and Con's for a 10,000 LB. Dump Trailers. #4
I have an Anderson 10K dump trailer. I have not yet hauled my CUT with it, but it would take some welding work first, to install tie-downs on the floor. I would not trust tying the CUT down with chains over the sidewalls. And I agree with PA..... you are looking at about 6000 pounds, so a 3/4 truck would be best.
I do use mine off-road though. It is mostly used to deliver firewood. My loading area is about 1/4 mile down a woods road. If you pay attention to how it's loaded, you can manage the tongue weight. I couldn't do it without 4WD.
   / Pro's and Con's for a 10,000 LB. Dump Trailers. #5
4wd is a must for a dump trailer, I have a 8X16 tripple axle dump trailer and it is a bear when you leave the pavement.
   / Pro's and Con's for a 10,000 LB. Dump Trailers. #6
they are higher and harder to laod im told than a regular trailer.
   / Pro's and Con's for a 10,000 LB. Dump Trailers. #7
My Anderson is a Low-Profile. It has tie-downs already in the bed. It would be nice if they were low on the wall verses on the floor.
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
UNKNOWN 16 T/A TRASH TRAILER (A53843)
UNKNOWN 16 T/A...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
