Proper way to remove and replace the FEL on an MF 1250.
   / Proper way to remove and replace the FEL on an MF 1250. #1
Workstead
Jonesboro, AR
MF 1010, MF 1250 with MF1246 Loader
My MF 1250 tractor needs to have the MF 1246 Front End Loader removed so the tractor can be split to replace the clutch.
What is the proper way to do this? I don't have the loader manual and the tractor service manual makes no mention of the procedure. I don't want to break any parts on the tractor. loader or myself while doing this. There doesn't seem to be any support brackets to lower, to prop up the loader frame after it is loosened from the tractor, and I believe it is too heavy to manhandle to the ground by myself.
Then there is the need to reattach it to the tractor when the split tractor is put back together.
Thanks for any advice on how to do this or for any links with this information.
Clem
   / Proper way to remove and replace the FEL on an MF 1250. #2
Clem,
Hopefully someone here has a manual to help you. Perhaps you can take some photos of your loader and post them here. Who made your loader? You might have to contact them, or a good MF dealer can answer your questions. Good luck and take plenty of photos.
hugs, Brandi
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
S/A Utility Trailer (A49461)
S/A Utility...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
