proper size disk
   / proper size disk #1
Oldstuff
Missouri
'63 Ford 2000
I did a search and could not find anything that will match the correct size for me, so, What would be the correct size disk for a Ford model 2000 with 36 engine HP and 31 PTO HP?
Thanks,
Oldstuff
   / proper size disk #2
depends on a lot of variables, width of disk, disc diameter, weight of unit, soil make up. I have an old ford 6' x 16" disk that is very heavy on a similar sized 4x4 tractor and it is all she wants in heavy clay soil, I don't think the 2 wheel would pull it. An 8' TSC special would probably pull like a toy behind that tractor.
   / proper size disk #3
There really is no correct size In feet as there are a few variables involved. With your tractor there are some eight foot disks you would not be able to move, others that would be ideal.
So, in general, consider looking for a smallish disk. Lighter weight with small diameter disks.:)
   / proper size disk
OK, then what weight limits are we talking- about 600 to 700 pounds maximum? If I was wanting a 66 to 72 inch wide in order to cover the tire tracks (tires are 64 inches wide) what individual disk size would I be looking for? This is a food plot on good quality top soil type ground (no clay or rocks) that gets replanted every fourth year. 6 foot wide by what diameter disk for this tractor?
   / proper size disk #6
My Ford 2000 had more than enough power for a light duty, 6.5 ft, 18", Dearborn disc. This disc was actually made for the lighter, and slightly less powerfull Ford n-series tractors. A 3-point disc of any make would be my last choice for a food plot tool. If you have nice soil, without a lot of rocks, consider a tiller. I have yet to hear from anyone, who has used both a 3-point disc and tiller on smaller plots, who prefers the disc. If your plots will be more than a couple of acres in size, consider a pull-type disc, which are far more effective that 3-points. Your tractor would easily handle a 8 or 10 ft pull-type disc. If you dont need to move the disc over the road after purchase, an old pull-type without a lift cylinder can often be had for a couple hundred bucks. A pull-type disc will do a better job with less weight per disc because all sections maintain better soil contact.
   / proper size disk #7
I had a 2000 Ford Gas on the farm some years ago and I got along well in various soil conditions with a 3 point 6 1/2 ft disc (20x18) weighing about 800. Ken Sweet
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
