Propane Tank - What to do
   / Propane Tank - What to do #1
L120
CCL Texas
JD L120
Hello friends,
After buying this beautiful country home, we have first of all gutted the house and installed new central air/heat heat pump. NOW...we are left with this huge silver propane tank in the back yard that isn't being used. I had the tank filled the first winter we were here that ran individual room heaters (scary shtuff). The tank gauge reads 60% full.
Can I tap into this fuel tank to refill my propane tanks for grilling delicious meats? Maybe there's alot more involved to do something like this.
How do I get rid of this tank?
   / Propane Tank - What to do #2
Hello friends,
Do you own it or does the LP company ? If it is yours and you are sure you do not need it I would suggest you contact LP companies in your area and inquire about having it evacuated and perhaps they would want to purchase the tank from you. There is a lot involved and transferring liquid propane is not for the un-trained or un-equipped. You could connect your gas grill permanently and would probably have enough gas for many many years.
Hi Jack,
Yes, the tank is mine. I remember the guy who filled it for me was very nice. Thought it best to ask some people what to do before contacting them. So my gas grill can use this same gas. Wouldn't be a bad idea, but it's in such a strange place in the backyard and I'd need to run pipe over to the grill. Now I'm hungry for steak...!
   / Propane Tank - What to do #4
The grill runs on vapor just like the house. If its a 500 horizontal at 60% you could have as much as 300 gallons it it ( + or - 7% ). You cant sell it or transport it full but 300 gallons would fire a normal grill for over 700 hours........if you think the advice or price offered is crazy run it by me I have been in the gas business almost 40 years.
Thanks again for reply. Wife agreed we could use it to fire the grill until propane is all gone. The reason I'm making such a fuss over it is because we are fencing in the backyard for the dawgs to do what they do.
   / Propane Tank - What to do #6
I'm in the same situation. Our house came with a 1000 gal tank in the ground. We have about 200gals left not being used. I just hooked it up to a pretty sweet outdoor LP fire pit and its fun. Doesn't throw heat like wood, but WAY easier.
   / Propane Tank - What to do #7
Good used tanks go for between 500 and1000 bucks around here and can be hard to find.
   / Propane Tank - What to do #8
I would consider keeping it. You could use it for a whole house generator/backup power, heat for a workshop in a future barn, or fire pit/grill like above. The propane does not really go bad and maybe you can put it to use someday.
   / Propane Tank - What to do #9
If you’re going to fence the yard, removing the tank could be a problem when you finally want it gone—-machines, trucks, etc. 300 gallons is a lot of propane for a gas grill. You own it, you are liable for it. If its old, if its corroded, if a regulator fails its on you. You are spending a bunch on the house, get it done right. Somebody will pump out the fuel, remove the tank, case closed.
   / Propane Tank - What to do #10
I bought a house with a heat pump, and installed a giant propane tank. but I'm a little farther north;)
propane doesn't go bad... and the price only really goes up over time.
if you see your self using the fuel for you bbq, fire pit, whole house gen set etc keep it.
if not... cal the pros
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2014 Mercedes-Benz Sprinter 2500 Ambulance (A51692)
2014 Mercedes-Benz...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
