Propane Tank Questions
   / Propane Tank Questions #1
JD5210
Veteran Member
Virginia
5210 MFWD
I have an underground 500 gallon propane tank. I was wondering how long they last?
I live in the western part of VA. It is close to the house and the ground around it is raised, so I would think it does not get to wet. I did a search and found the soil type is silt loam or silty clay loam, and averages 22 to 32 percent clay and 2 to 6 percent sand.
Another question how often does the anode bag need to be replaced?
Thanks in advance for any help.
   / Propane Tank Questions #3
the soil in that area is most likely has been attacking that steel tank for a long time.
One would think it had some sort of cathodic protection, such as anodes, etc,. But who knows.
JMO,, I wouldn't want one that was buried at all .
   / Propane Tank Questions #4
I struggle with the buried tank issue also. I can't think of any reason to bury one beyond just not wanting to look at it. I understand that to an extent. But then we start talking about long term and I've never heard of a solution to analyzing the condition of the tank. Until it fails. That part bothers me enough that I have no problems with looking out my shop window and seeing a propane tank. :)
   / Propane Tank Questions #5
My parents tank has been buried for over 30 years. As of now it’s not leaking or at least not enough to be detectable heavy clay soils
   / Propane Tank Questions #6
My above ground tank is a '51 model. I have no evidence of how long it would have lasted buried.
   / Propane Tank Questions #7
This is the first time I ever heard of propane tanks being buried !
As far as I know there aren’t any buried here in Wisconsin.
   / Propane Tank Questions #8
I have a 1000 gal buried tank. The propane supplier is supposed to check the cathodes with some sort of meter every couple of years.
   / Propane Tank Questions #9
States with soft sandy soil, in a hurricane zone. the tanks can pop out of the ground. If you have a buried tank and expect a hurricane land fall, you want to make sure tank is filled.
   / Propane Tank Questions #10
1,000 buried here as well.
Yanmar YFL-1575 33HP Utility Loader Tractor (A49461)
Yanmar YFL-1575...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2004 INTERNATIONAL 4300 CARGO TRUCK (A50854)
2004 INTERNATIONAL...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
