Snowblower Pronovost P-740 snowblower
   / Pronovost P-740 snowblower #1
Rowski
Veteran Member
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Here are a few pictures of the P-740.
Specs are:
Weight 1250lbs.
Working width 74"
Impeller diameter 26"
Impeller depth 12"
Main auger diameter 23"
Drive chain to auger 80
Hydrualic motor for chute rotation 310 degrees
Hydraulic deflector on "semi industrial chute"
Adjustable skid shoes
Picture shows the heavy bracing to the corners of the blower. Also a good shot of the hydraulic motor for chute rotation of 310 degrees.
This picture shows the front (or rear) of the blower. Notice the heavy 1/2 thick wear plate at the lower side edges of the blower box. Also notice the auger drive chain is enclosed, this keep rocks and other debris from becoming wedged between the chain and sprockets.
   / Pronovost P-740 snowblower #4
I looked at one of these that was on Ebay last summer. The guy was in western Mass. It was built solid like the rock of gibralter. The P series is their heavy duty industrial model. Made like a timex, takes a beating and keeps on ticking.
I have a 64 inch Puma which is Pronovost's lighter duty unit. It is built solid too.
Another view from the other side. The "semi industrial chute" (that's what Pronovost calls it) does not leak any snow when direction the snow straight down.
Another view. Show the chute well. Also the bracing for the blower box.
This is a picture of the "self tensioner" for the auger drive chain. It is spring loaded and keep the right tension on the chain. Also the chain is an "80" chain. I'm not sure what the number means (other than a rating). But is sure look very rugged!
   / Pronovost P-740 snowblower #8
Nice unit's aren't they! /forums/images/graemlins/smile.gif
   / Pronovost P-740 snowblower #9
Left my wife with 20 inches of new snow and only a back blade to clear the 400 odd feet of driveway. So this is interesting.
Er...how far does it toss the snow. Hmm a better question how far would it toss a rock(I have a gravel drive) ? Don't need to be bombing my neighbors with snow thrower launched missles.
TC-30, FEL, back blade
Ender
   / Pronovost P-740 snowblower #10
Looks like a nice unit, that 80 pitch roller chain is stout! Mind if I ask what one of those units goes for? I need to upgrage my snow removel tool before next season. Also, how big a tractor do you need to drive that bolwer?
Thanks.
Bri
KSI Conveyor (A53472)
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
STORAGE FEES (A52577)
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
