Procedure for adjusting the valves on a 3016
   / Procedure for adjusting the valves on a 3016 #1
Walter L
Delhi LA
LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
Need to check the valve gap on my 3016 S3L2 28 hp Mitsubishi engine, I did a search but could not find the procedure posted if anyone has it I would appreciate a copy of the procedure.
Walt
   / Procedure for adjusting the valves on a 3016 #2
Don't waste your time unless you hear valve clatter. I know what the manual says but you'd be hard pressed to find any new engine that actually needs it.
   / Procedure for adjusting the valves on a 3016 #3
I agree with oldpilgrim.
Thanks for the suggestion but I should have said it's a 2013 with 1000 hrs and it is time to check and reset the valves gap.
Walt
   / Procedure for adjusting the valves on a 3016 #5
Even then, don't worry about it.
thanks guys for the comeback but I think I can work out the procedure.
   / Procedure for adjusting the valves on a 3016 #7
As "oldpilgrim" said no worries, mine is a 2011 and I have not had to adjust the valves. I have had it since it was new.
   / Procedure for adjusting the valves on a 3016 #8
How do you guys know it's not necessary if you've never checked yours ? I'm sorry but even having been a professional mechanic for over 45 years I cannot tell if a solid lifter is out of adjustment simply by listening to the engine, especially a diesel engine. A couple thousands loose will not make any more noise than one that is set properly and a tight one will be even harder to tell. It's just good practice to check an adjustment that's supposed to be checked at some point.
This is the procedure in case needed
Find top dead center compression position for #1 piston by using the procedure that follows:
a Turn the crankshaft until TDC mark on the crankshaft pulley is aligned with the mark on
the timing gear case.
b With No. 1 piston at top dead center on the
compression stroke, the rocker arms will not be moved when the crankshaft is turned approximately 20ー in both directions.
c If the rocker arms move, No. 1 piston is at top dead center on the intake or exhaust stroke. In such a case, turn the crankshaft 360ー in the direction of engine rotation again. No. 1 piston is now at top dead center on the compression stroke.
3. Loosen the lock nut for the adjusting screw. With a feeler gauge inserted between the rocker arm and valve cap, adjust the valve clearance by turning the adjusting screw.
Firing order on the S3L2 is 1-3-2
This book I found this info says both exhaust and intake set at 0.25 mm or
0.010 inch
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2019 Nissan Versa Sedan (A50324)
2019 Nissan Versa...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
