Problems with To-30 Ferguson Motor
   / Problems with To-30 Ferguson Motor #1
marleejeneen
Booneville, MS
to-30 Ferguson
I have a 1950 to-30 Ferguson tractor. The motor will turn over but it won't crank. Any suggestions?
   / Problems with To-30 Ferguson Motor #2
SO
A little more information whould be helpful. I flunked Mind Reading 101-ask my wife!
Are you saying you can turn the engine over by hand but the starter won't crank the engine over? Does it have the OEM starter system? Does the starter make a whirring noise when you push the transmission lever to the S position. If it does than the starter drive needs replacing. If it doesn't make any noise, it could be a bad connection, bad ground, corroded battery terminals, corroded battery cables, bad starter switch, bad battery or bad starter.
I can't be of more help with out more info.
   / Problems with To-30 Ferguson Motor #4
as jerry said.
so far you have told us the engine is free but starter won't turn it.
when you get it rollig over.. does it have spark.. good spark on all 4 plugs?
if so.. will it bang on start fluid sprayed into carb mouth with throttle open?
post back some details
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2005 INTERNATIONAL4300 WRECKER (A53426)
2005...
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
9 OFFICE CHAIRS (A53843)
9 OFFICE CHAIRS...
