OK--I finally got my BX2200 with FEL, 60" MMM, Box Blade. Dealer delivered it to the house. I get home and decided to try it out and mow about 3 acres of grass,
1st Problem -- You cant use any rear implaments with the MMM attached. Easy fix -- remove the box blade.
2nd Problem -- FEL makes the front end too heavy and the thing bounces everywhere. The solution that helped was to raise it up as a temp fix. I guess I will have to remove it every time I mow.
Third problem. -- I was getting a little uneven cut when I turned the corner. I pulled the mower over to the driveway and the antiscalp wheel on the front right side (discharge side). The antiscalp wheel was almost torn off the shaft. It was hanging abot 2" from the post. It looks like it is ruined.
It appears that the deck was not level it was about 3/8" out of level. Should I ask the dealer to replace it, or should I should I cover the cost. I put about 2 hours on it.
Also another concern, does the blade belt flop around alot on the back side? Mine does, Should I tighten it?
Ricky
Ricky
