Problems with my lift arms on my Ford F 2000. Besides low on hydraulic fluid or pump. What else should I try to get my hydraulics to work.
   / Problems with my lift arms on my Ford F 2000. Besides low on hydraulic fluid or pump. What else should I try to get my hydraulics to work. #1
Ford@1968
Nederland Texas
68 Ford F2000
   / Problems with my lift arms on my Ford F 2000. Besides low on hydraulic fluid or pump. What else should I try to get my hydraulics to work. #2
Really the question needs to be asked did they work prior or just recently stop working. Typically hydraulic system works if the following conditions are met. 1. Sufficient hydraulic fluid. 2. Clean filter 3. Working pump Now with that being said if there is fluid leak on low pressure side it will introduce air into the system. Compressing air results in poor hydraulic performance slow or jerky. Lastly water in the hydraulic fluid is even worse causing more issues. I just purchased IH 504 and its previous owner never changed hydraulic filter so when unit ran it whined loudly. Once changed hydraulic pump quiet down and worked as expected. Look for the obvious as your troubleshooting the ford 2000.
   / Problems with my lift arms on my Ford F 2000. Besides low on hydraulic fluid or pump. What else should I try to get my hydraulics to work. #3
What version 2000? Can we assume 3 cyl or is it a 4 cyl
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
Grundfos Centrifugal Pump (A50121)
Grundfos...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
New Holland L225 Skidloader (RIDE AND DRIVE) (A50774)
New Holland L225...
40' CONTAINER (A51244)
