hou
I had such great help with my solenoid system, especially from souNdguy, I thought I would ask for more help with a hydraulic lift problem. The tractor is a 1963 Ford 2000. The lift was suppose to have been rebuilt several years ago but has never worked right since the repair job. The lift will pick up when I pull the lift lever all the way to the top it comes all the way up. It doesn't even begin to start lifting until I am about one inch from the top of the lift lever. It will hold the all the way up position with ease. In fact, it will hold it in the up position with a load for many hours with the tractor off. The lift only works in the position control (lever up) position. If I change it to draft control(lever down) it will not lift at all. I changed the hydraulic fluid and used the Tractor Supply brand. It did begin to lift a little better when the tractor has been running for 30 minutes or so since the fluid change. However, it still doesn't begin to lift until I get about one inch from the top of the lift control lever. Is there any adjustments that can be made? Thanks
Hou
Hou
