problems fitting 6' mower on my 3720
   / problems fitting 6' mower on my 3720 #1
B3200
Bronze Member
Erie Pa.
kubota b3200
My new (to me) 3720 with cab,and 40 hours on the clock, went to the local dealer for a new 6ft. mower to be installed,(2 weeks ago), they say that they can't figure out how to install one of the brackets underneath because it hits the hydraulic fluid supply tube underneath is in the way??, they are trying to figure it out but it's taking a long time. Has anyone run into this same problem? thanks
   / problems fitting 6' mower on my 3720 #2
The following comment represents a shot in the dark.
I switched from a 2008 O/S 3320 to a 2007 CAB 3320 and kept the original 72" 7-Iron and all brackets / mounting hardware etc.
One of the brackets was not compatible with a CAB model and had to be replaced with new bracket LVA14927. Sounds like your 3720 is newer, but maybe a similar problem. Perhaps they are trying to fit a bracket for an O/S model.
Thank you, i will be making a phone call to the mechanic on monday
PAIR OF 10 TON AIR LIFT JACKS (A53843)
PAIR OF 10 TON AIR...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
