Problem with Massey 1433
   / Problem with Massey 1433 #1
JimWolf
no city, Connecticut
Massey 1433
I have a MF 1433 and the bolts from frame to engine keep coming lose. We have tried red Loctite with no success. Any suggestions? I would also like to know whether this make and model have been having this problem in general.
Thanks.
Jim
   / Problem with Massey 1433 #2
How about a picture.
A bolt hole which has worn oversize from being loose is not going to have a bolt stay tight no mater how much loctitie you use.
You may have to re-drill the holes and fit a slightly larger bolt that is snug in the hole. When trying to find slightly larger dont forget to consider metric.
Same problem occurs on vehicles. If a wheel comes loose the hole on the wheel will be worn slightly larger and the tapered surface the nut seats against is no longer a perfect circle.
The wheel will continue to come loose no matter how tight you make it. A new wheel is the only answer.
Dave M7040
2014 Infiniti QX60 AWD SUV (A53424)
2014 Infiniti QX60...
2017 CATERPILLAR 908M WHEEL LOADER (A52705)
2017 CATERPILLAR...
CAT CS563 (A47477)
CAT CS563 (A47477)
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
CATERPILLAR 255 SKID STEER (A52705)
CATERPILLAR 255...
