Problem with login / posts
   / Problem with login / posts #1
Guys do you know if there has been a problem with the site
It has been over two weeks and I still can't login - also after looking around it looks like all my posts have vanished - I have been going to the "report problem area" and filled out the form explaining what is happening - I did this four times and still have no response - I gave two different e-mails and a phone number as well - no response - was wondering if anyone else is having problems - it seemed to happened when I was using the private message area - do you guys see my posts? - This is ED - used to log in as eambrose
   / Problem with login / posts #2
Ed,
There was a hard disk problem. Certain registered users were "lost".
You must start all over--reregister.
Your old posts are still here under "Poster"--the same identification applied to a number of other users in the same boat.
Bob
Hey Bob - thanks - thats too bad - I do see the posts now
have you had a chance to mow yet??
- I do miss it as i mentioned I have problems with the Walker - it has two bad hydrostats (Eaton Model 7's) The dealer gave me a $1600 credit for the problems
- I am fixing it myself so I know what I have - I talked to the former owner and it really only has 390hrs so I can't understand how the hydros went - must be from sitting outside - The engine is runnning good now - I found the Eatons new on the net for $250 each - so that leaves room for any other parts I need - I should be in good shape then - I have a new deck for it 48inch GHS - may consider a second 56 or 62 side discharge
I can't believe the difference compared to cutting with the 72 inch - takes a lot longer and the cut was better with the lastec but it is pretty nice with this one - It is nice to have the vac built in and the mower always set up vs the PT - Once I have the wheel motors at full power I am pretty sure I will be able to mow 99% of my property because I'm almost there now
   / Problem with login / posts #4
Ed.
Did you re-register with your original username? If not, please do so. Thanks for being patient. As was mentioned, there were some hard drive problems and TBN is doing the best they can. Thanks.
1998 NATIONAL TRAILER (A55745)
1998 NATIONAL...
Mini Excavator Attachment Set (A53316)
Mini Excavator...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2019 Chevrolet Silverado (A55852)
2019 Chevrolet...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
23311 (A51694)
23311 (A51694)
