Backhoe Problem with BH4560 backhoe hydraulics
   / Problem with BH4560 backhoe hydraulics #1
rossibob
Virginia
Kubota 3710
Well, I got out on the tractor on Sun. The backhoe was working very well to start. After about an hour I noticed that I had fluid coming from the two swing arm cylinders that I had just rebuilt. It may only be coming from one and just crossing over to the other through the hose that runs between them. ??? Soon after i noticed that the main lift for the backhoe kept sagging. I would have to keep pressure on the lift handle to keep it up. If I wanted to move the tractor, I had to put the transport locking pin in to keep it from dropping to the ground. I don't know if the problem is in the valve or in the cylinder. Any thoughts??? Rossi Bob
   / Problem with BH4560 backhoe hydraulics #2
Bob,
If the swing pistons are leaking, something did not get sealed properly. You may also have a valve problem, but what you are describing is a leakycylinder.
I think you need to look at those pistons again. Make sure the seals and orings did not get damaged during installation. And make sure there is no dirt inside.
Good luck.
Gary
On the beach in Ft. Lauderdale! /forums/images/graemlins/crazy.gif
Thanks for the reply. I will pull down the cylinders and see whats up with them. Concerning the second problem with the lift arm not holding, I am leaning towards the fact that I might have a valve that is sticking or needs to be replaced up near the controls. /forums/images/graemlins/confused.gif
   / Problem with BH4560 backhoe hydraulics #4
Bob,
It is a real possibility you have a valve problem, but it could also be a seal problem. It maybe bypassing internally. I think since the swing pistons were leaking, it is possible the others might be also. That is the case with mine. I am not sure there is an easy test for checking a valve versus the piston, maybe others can offer some suggestions, but once you get the hang of it, resealing the pistions really is a easy task. /forums/images/graemlins/smile.gif
Gary.....
Only 15 days till I can leave the beach /forums/images/graemlins/confused.gif
Went out just to try the backhoe today. It worked great for about 45 minutes. Then the boom started to sag on me again. From this I surmise that my problem is a cylinder seal. I would guess that when the seals get hot, they don't hold the fluid properly. Does anyone agree??? Thanks
   / Problem with BH4560 backhoe hydraulics #6
Not to mention the fluid will also thin out a bit when hot. I think it is reseal time. I plan on doing the rest of mine wether they need it ir not when I get back home.
Good luck,
Gary
Still on the beach /forums/images/graemlins/frown.gif
   / Problem with BH4560 backhoe hydraulics #7
My take is to stop the cylinder leaks first. Hard to blame a boom drop on a valve, when a hydraulic circuit is bleeding. Once the blood stops, then maybe the valve can be considered as the culprit, not sooner. At least not in my limited world. /forums/images/graemlins/grin.gif
Thanks guys!!! The seals are on order. Bummer Monday is a holiday. I guess I will have to find some other work to do. I better not say that to loud my wife is near by and I'm sure she could find some not so fun work for me to do. /forums/images/graemlins/grin.gifOff to the great outdoors and away from the laundry room and kitchen if you know what I mean. /forums/images/graemlins/wink.gif
Well, I got the new cylinder kit in and got it mounted. Today I got out and had a great time digging stumps. Once again, after about an hour the boom started to slowly drop. Now I must asume the problem is in the control valve. They know me by first name at my Kubota dealer parts counter. I must say that they like the fact I come in knowing the all the part numbers I need. My wife says that she is now a tractor widow. /forums/images/graemlins/smirk.gif
   / Problem with BH4560 backhoe hydraulics #10
The arm control valve has a check ball to keep pressure on the cylinder when the valve in neutral. Locate the valve in question and in the front of the valve it will have a port that looks like it is plugged. Take the plug out and be careful not to drop the spring that holds the check ball in place. You may find you have a weak spring or trash in the seal area.
Did this make any cents /forums/images/graemlins/confused.gif?? hehe. My mind is weak but my back is strong.
Hope this helps.
Bill 528 Grain Cart (A50774)
Bill 528 Grain...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
2012 Dodge Bucket Truck (A50323)
2012 Dodge Bucket...
2013 John Deere 160G LC Excavator (RIDE AND DRIVE) (A50774)
2013 John Deere...
International 1420 Combine (A50514)
International 1420...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
