bkeith85
I'm having some trouble with the spindles I just bought for my Dad's 53 Ford Jubilee. This is the second set I've bought. I sent the first ones back because they weren't machined correctly. I ordered a pair from a different supplier and these are the same way. Both places tell me they have sold lots of them with no complaints. So I need to know what the trick is to get these to work. Compared to the old ones, the shaft that goes through the hub is just too short. If I assemble it without the seals, I can just barely get a thin cotter pin through the hole. The correct sized pin will not fit. I measured the old ones and the new ones are about 1/8" shorter. I thought I might have the wrong castle nut, so I ordered new ones and new tab washers. The new washers are thicker than the old ones, so those won't work and the grooves in the nuts are too shallow, so I can't even see the cotter pin hole using the new stuff.
The other problem is these weird seals they sell for the hubs. With the seals in, the hub won't go on all the way to let the inner bearing seat. If I tighten it down, I can get a cotter pin in, but then the hub barely turns because the seal has to be compressed about 1/8" at this point. These are the same seals that everyone uses and they are installed with the rubber to the spindle face. I found some better looking seals from another company and will try those when they get here. They look more like a regular dust seal with a thinner edge, not the thick block of square rubber like these.
More info: I have one old hub and one new one. The old hub is using the old bearings, which were still good. The new hub got new bearings and races. It was listed as fitting Ford 8N and NAA, so it should be right. I did not order a bearing "set", I just bought bearings by the numbers at the parts store. Do they make special bearings that are thinner to work with these funky spindles? Both hubs fit the same, so I don't think that is the problem. I pressed the bearings in, so they should be seated all the way.
I've been stuck with an unusable tractor for about a month now and I don't know what to do. Has anyone here bought new spindles and gotten them to fit right?
