Problem with a Series 4 PTO Shaft
   / Problem with a Series 4 PTO Shaft #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
I bought a rotary mower and the tractor end of the PTO shaft has disappeared and the replacement is too short. I have to make it about 30 inches longer. It is a Series 4, the 43.5x3.4 (outside) end. I have found the right sized tubing. How do I get the coupling end off the old shaft? Or is there a way to splice the tubing?
   / Problem with a Series 4 PTO Shaft #2
Usually it's just a roll pin holding the tubing in place. The tubing does fit very snug in the yoke, so it can be a pain to take off.
Ah yes, upon closer examination, there is a roll pin. OK, after the roll pin is removed what is the advice for getting the tubing out of the yoke? I would soak in diesel fuel, but don't want to soak the bearings.
   / Problem with a Series 4 PTO Shaft #4
With a punch and hammer, try tapping on the end of the tubing through the U joint side, which can be tricky.
   / Problem with a Series 4 PTO Shaft #5
Cut the shaft flush with the yoke, take a sawzall or similar tool and cut the short piece of shaft still in the yoke lengthwise so it will collapse enough to pull out. You may have to cut it twice.
7021 (A50322)
7021 (A50322)
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
